Question about HP Compaq Motherboard
Motor boating on Compaq Presario 1800 Mboard
My Compaq Presario 1800 stopped powering on at all except for a rattling noise on the floppy that happens the same with power supply OR battery. After a full disassembly, I get this same rattling (that sounds very much like "motor boating" as it is commonly referred to in electronics) when I connect the motherboard with just the tiny PCB that holds the power-on button & other Compaq buttons. Does anyone now of such a problem? Basically, I would like to make sure that such a noise is indeeded abnormal in my test configuration (motherboard with just the buttons PCB plugged). I intend to try to debug the power supply (faulty capacitor) and if that fails, maybe buy a spare motherboard. Any comment is welcome.
  • 432 Answers
Could be the cpu fan?
Posted on Jun 22, 2007
SOURCE:
How Can I Upgrade BIOS On An HP Compaq Presario 2175US?
Open the website chose your model and then download updated Bios software and drivers then burn a CD and follow the process of updating.
Good Luck
Aug 13, 2012 | HP Compaq Presario 2175US Notebook
Remove A: drive compaq presario sr1055cl
Remove the side panels on your desktop computer. The floppy drive will be attached to the drive bay with 4 screws (2 on each side of the floppy drive) or by a plastic slide clips. After removing the screws, remove the power cable and the data cable from the back of the floppy drive and then you can slide the floppy drive either to the back or the front of the drive bay to remove the floppy drive from the desktop case.
Feb 08, 2012 | Compaq Presario sr1055cl PC Desktop
Compaq Service Utilities floppy Presario 2100
Access: http://www.compaq.com/support
and search for 'Presario 2100', then click on 'Device Drivers'.
Nov 07, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Update bios on compaq presario m2000?
There are usually two ways with Compaq's
One is with a DOS boot floppy
The other is via a windows utility
both are usually available from the support section on the Compaq website.
Heads up only do this on mains power not battery !
DON'T stop it or switch off for ANY reason
If you knew how many crashed bios questions come through Fixya.
Check the text file or only as to what problems that bios fixes and if they don't apply to you then don't do it.
Most bios updates fix very minor issues nowadays
Sep 09, 2009 | Compaq Presario M2000 Notebook
Compaq presario 900 512 ram to 1 gb?
go here http://www.corsair.com/
and do a memory scan
Jul 07, 2009 | Compaq (291647-001) for Presario 900 /...
Keyboard stuck
Disconnect the power cord and remove the battery. Wait for 30 seconds. Next, put the battery back in the laptop and reconnect the power cord. Turn the laptop on.
Be sure to also run a virus scan\malware check and update all your drivers.
Jun 01, 2009 | HP Compaq Presario 1700, 1700AI, 1700AP,...
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Floppy drive doesn't work.......not listed on My Computer
some one change your bios configuration and there make floppy drive disable you need to enable that then you can see your my computer list
Jan 18, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario 1200- no power-
i dont really say if your mboard will get a damaged..try to change your power plug..if it still not working, you have to open your laptop, so you can find or know if there's some thing wrong...maybe you should have to buy a new one instead of replacing it..coz, if some parts of the motherboard also have damaged, its very hard to fix.. the parts are very small and delicate to fix it..thanks..
Feb 20, 2008 | Compaq Presario 1200,1600, Series CD...
Laptop Boot Problem
It seems all Compaq laptops are infected by this problem. If you are sure that the AC port and the AC adapter is working? Can you hear the laptop trying to boot? ..e.g. Hard Drive spinning up, Floppy Disk Drive noise, etc.. if so ...Try hooking up a external monitor.. Does it smell like anything has burnt? (Call for service) Is there anything that sounds loose when you shake it? (Call for service or you can to open it?) Try booting your laptop from a bootable floppy if you have one. Or use Compaq's Recovery CD. But I doubt if you use recovery CD, you might lose data on your HDD. Which O.S. are you using? The Boot-up mechanism checks all the hardware before starting Windows. Some times floppy drive doesn't allow the laptop to boot further by either not responding or sending wrong signal.
Jan 16, 2006 | Compaq Presario 1200XL104 Notebook
HP Compaq Motherboard Logo
194 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
