Question about Westinghouse LTV-20V4 20 in. EDTV-Ready LCD Television
No picture on a Westinghouse lcd tv model ltv-20v4
I have a westinghouse lcd 20 tv...I get sound but no picture...any suggestions...? I have they same problem and I am not sure if I need the LCD unit or the power supply. They repair shop wants more than it is worth to fix.
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
The simplest problem would be the failure of the backlight.
In case you don't already know it, there is one, and they may or may not last forever.
Also, there is an extra power supply to produce the high voltage the lamp needs to fire that may have failed.
Sometimes, you can look at the screen from an angle to see if there is any sign of movement.
If you can see program material causing a change in the faint image, then you can be pretty sure it is one of the two problems mentioned.
Posted on Sep 01, 2008
  • 3 Answers
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
I have a line in the middle of my screen.what can I replace to fix this?
To be honest, you're not going to like this but... the simple answer is to replace the TV. You've got a short on the circuit board that controls the LCD display. You could replace the board, but for a 20" TV it's actually cheaper to buy a whole new TV. Hope it's under warranty!
Nov 03, 2010 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
My westinghouse flat screen tv - i turn power on picture comes on for a few seconds and goes black - sound still works - any suggestions?
The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Oct 07, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I need a remote code for a westinghouse LCD TV, model LTV-20v4, with a MOTOROLA remote control
Hello, if the remote is a universal remote you will most likely need to input the Sony codes. Another option is to purchase an original remote at parts@wde.com, the price for the remote is $15 plus $5 shipping and handling.
Dec 14, 2009 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse SK-32H640G LCD TV has picture but no sound. Its hooked up with HDMI cable, I've checked audio settings and TV speakers are on, and also have tried both HDMI ports on TV please help!
Hello, these are fairly new units as they have not been out in the market for that long. With that said I would recommend checkin if the audio is good using other inputs like the Tuner, Component (yPbPr) or simply RCA cables, if there is sound than mostlikely you will need to replace the main board. I would recommend to call Westinghouse customer care at 1800-701-0680 for further assistance.
Dec 06, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have sound but no picture a all on a Westinghouse LTV20v4. The menu does not come up.
Check for bad capacitors in the inverter board, it may have taken out the 8 transistors when the caps went open.
See the picture here: http://s807.photobucket.com/albums/yy352/budm/WestingHouse_LTV-20V4/
Nov 07, 2009 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-20V4 20 in. EDTV-Ready LCD Television Logo
66 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
