Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar size what is the biggest bar i can use on this saw?
  • 59 Answers
According to Husqvarna a 3hp saw will allow bar sizes 13"-20"
Posted on Sep 18, 2008
Chain saw chain for rcs5145n purchased from bunnings Tuggerah NSW who do not carry genuine parts fo this machine
as saw chains are made by generic companies for saw manufacturers , any quality brand will fit and do the job
you can get the chain or chain and bar as assemblies
just get the correct length --the size is the bar size printed on the bar
example 400 mm is bar size and the chain will be sized as 400mm
Jun 04, 2017 | Garden
How to correct no oil flow to bar on Model172.34120
ive not done much with this model but I can give you some basics on why I see lots of chainsaws loose there oiling of bar
(1) Wrong oil used in supply tank- most all chain saws take 30 wt bar chain oil . this is a lite/fine oil and needs to be so it flows thru small ports and pump on saws
(2) fine sawdust in supply tank - I guess anything can fall in the tank but I do find theres a lot of junk that falls in there over time , if it don't flow like oil does then it don't belong in the tank
(3) sawdust jammed in bar ports this id say is the biggest one I find , seems sawdust (all different size pieces) finds its way into the fine ports that oil is suppose to flow thru , sawdust mixed with oil makes a darn fine plug !!!
other than these simple things above , most saws have lots of parts that can break and fall off look for something just not right looking and sometimes it will be very obvious whats missing
Jul 19, 2015 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have husky 435 and want to put a 14" bar on the
Most all brands of chain saws will except one size smaller and one size bigger than what came with the saw. You just have to make sure the bolt holes and the hole for the adjustment pin match the origional bar.
Aug 26, 2012 | Garden
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the biggest bar and chain i can use
The recommended length of bar for the 460 is 13 to 20 inches. I wouldn't go over the recommended length as it would put extra strain on the motor.
Dec 05, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
Can i switch my 18inch bar to a 20inch bar on the poulan wildthing
Oregon lists nothing beyond 18". I would not go beyond that.
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
If you need a 20" Home Depot rents 6401 Makitas (blue Dolmars). Biggest danger here is you will never be happy with the Wild Thing again. You can often purchase a used Makita at Home Depot for a very good price. The 6401 can be modified to a 7900, a lot of saw. HTH
Lou
Oct 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I would like to go down A bar size our two on my poulan wildthing
I have a Poulan Pro 295 20".  When I bought it I also bought a 16"bar and chain and have been using those since.  They make the saw much easier to handle and are a better match to the available power. The key dimension is from the bar's mounting hole to its end.  At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there.  This can be easily seen by laying one bar over the other.
Apr 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
110 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
