Question about Dishwashers
Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
OK, just when I thought I would get around to fixing this 6-year old washer, another thing is now not working... guess I'd better get busy!
1) The dishwasher interlock does not work. You can press any desired cycle, and the machine will start running through the cycle. Even if the door is open! Does not detect whether the door is open or shut. Sounds like another part to fix?
2) For some time, the dishwasher rinse-aid has been leaking. Fill it one time, and it almost all leaks out in first wash. So we stopped using it in the meantime.
3) Finally, the soap dispenser opens -- sometimes -- but not others. So we manually watch it to be sure it starts. I saw the other posts on Bosch dishwashers, and that this is probably a solenoid actuator mechanism. Will start looking for how to order online.
  • DHS1 Sep 10, 2008
    Thanks - will try the door lock issue. When I had the door off to get parts numbers, I also managed to do something with the right hand spring. Took out one screw at top, then when put back in, it now does not open correctly - only goes to like 80 degrees open, instead of 90 degrees. Guess I need a right hand spring. Yeesh.
Don't know what you did with the spring but it only needs replacing if it is broken
Posted on Sep 11, 2008
    President:
  • 1,462 Answers
Door lock is in the wrong position. open door and use 2 small screwdrivers to lever lock to correct position. bend the hook on the cabinet slightly downwards if it is a metal hook
rinse aid and detergent dispensors are 1 item. could well be faulty but can also be module. check you are getting volts to the solenoid at appropiate part of the cycle
Posted on Sep 07, 2008
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
My soap dispenser is not opening during the cycle.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 05, 2011 | Bosch 24 in. SHY66C05 Stainless Steel...
My dishwasher says rinse aid,
From what I get from the question, it is asking to add rinse aid to the rinse aid compartment next to the dish soap compartment.
Dec 21, 2010 | Bosch Dishwashers
Accidentally put cascade dishwasher detergent into my rinse aid dispenser! What do i do to get it out?
Funny, that happened to me too recently. So far I've taken the front panel off and can see all the 'muck' in there. I've been reading, remove it (shut the door and push INTO the unit and clean and replace is my plan...
Jan 05, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Very filmy looking glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 31, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Bosch dishwasher SHU66C02UC - Rinse Agent issue
Does soap draw open at right time?
Same solenoid opens soap draw as injects rinse aid.
Turn up hardness counter ?
Any blockages in dispenser unit its-self?
OTHERWISE CALL IN THE PROFFESIONALS !
Apr 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
416 people viewed this question
Top Dishwashers Experts
