Question about Samsung Cameras
Been out in the rain and despite covering my digital slr it may have got damp. Now it won't switch from manual to auto focus even though the switch moves. Is gentle drying likely to cure the problem?
  • yorky2709 Sep 07, 2008
    Camera is a Samsung GS 1X digital slr
  • Greg Cann
    Greg Cann May 11, 2010
    Please supply the make and model number of your equipment for example "Nikon CoolPix 3200", so that we can help you.
    Best regards,
    Informatica
Took lens off the camera and let it dry out in gentle heat over a period of five hours. The problem seems to be solved.
Moral of this story; don't put too much faith in waterproof covers during very heavy downpours!
Posted on Sep 07, 2008
Rewind sound when switched from auto focus to manual focus
Probably a problem with the af/m switch so that even though switching to manual moves the connector out of the way (pulls it into the mount) the af motor continues to run. Remover the bottom and then the front cover and check the switch.
Jan 23, 2014 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
I can't get my camera out of auto focus
Did you push down the lever on the side of mirror box to switch it to manual focus? If so and it is still not going into manual focus, then the switch may be damaged (bent switch contacts etc.). You can check the switch by removing the bottom and front covers. Beware of loose parts!
Oct 27, 2013 | Minolta Maxxum 400si 35mm SLR Camera
Polaroid 690 SLR-The switch between manual focus and auto focus, does not appear to operate normally. Maybe I do not know how to use it, however I cannot manual focus. Are you familiar with this camera and...
Not sure if this will help, but according to the manual, to use manual focus, push the button down until the red portion is visible, and turn the manual focus control dial until the image appears in focus in the viewfinder. Then, take the photo as normal. To return to autofocus, just return the switch to its normal position.
Sep 15, 2011 | Polaroid 690 SLR Instant Camera
Camera will not focus in auto focus mode and when it is focused manually it will not recognize that it is in focus. The instruction manual doesn't cover this case and I was wondering what was wrong with...
You need to have a compatible lens to be able to autofocus. Some older Nikkor lenses and even more so 'generic' lenses (ie. Tamron, Sigma, Opteka etc.) do not autofocus or can be used with Nikon bodies.
Check that the lens is compatible with your camera.
Jun 19, 2010 | Nikon N55 35mm SLR Camera
My connon xti 10.1 mp takes many out of focus pictures even though its on auto focus how can i solve this problem
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
Dec 29, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
My Nikon N55 will not auto focus.
Depending on the type of interchangeable lens you have mounted on the camera, there may be a switch on the lens barrel for choosing between auto-focus or manual focus. The N55 also will not auto-focus with the newer Nikon AFS lenses such as those used with the Nikon D40 digital slr. Finally, there was a service bulletin on the N55 back in 2005. Nikon discovered a problem with the auto-focus and fixed it for free, but there may have been a time limit. Here is a link to more info about that:
http://www.nikonusa.com/Service-And-Support/Service-Advisories/N55-Service-Advisory.page
Hope this helps : -)
Nov 30, 2009 | Nikon N55 35mm SLR Camera
Auto Focus wont work...
Try this...clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 04, 2009 | Nikon D100 Digital Camera
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Cameras Logo
55 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
