Question about Singer 7462 Mechanical Sewing Machine
Button Hole Beeping on 7462
Every time I try to sew a button hole I get a beeping sound. The button whole presser foot is on, the button whole lever is down and the correct stitch is selected. I tried sewing a straight stitch and that is working fine.
Can someone help?
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Posted on Oct 26, 2008
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
Singer 7444. Can't use button hole. I have
try changing the needle
clean under the needle plate and in the bobbin area
and make sure you use every thread guide
Aug 11, 2013 | Sewing Machines
Cannot get the auto buttonhole to work..it beeps and I can't find the problem
there is a button hole lever to the left of the needle & you pull it
down gently against the button hole foot & the beeping should
go away
Aug 25, 2012 | Singer Confidence 7469 Mechanical Sewing...
Trying button hole attachment- installed properly I think - when I push on presser foot an alarm goes off and it will not sew
Hi Dot,
1. Make sure you pull the buttonhole lever down- left back of your machine.
2. Select the button hole icon, or select the corresponding number for a button hole-very important.
Good Luck
Sep 07, 2011 | Singer 7426 Mechanical Sewing Machine
The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
May 22, 2010 | Singer 7462 Mechanical Sewing Machine
Machine beeps and won't sew when buttonhole foot is attached - I have followed directions very carefully
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
Dec 12, 2009 | Singer 7462 Mechanical Sewing Machine
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
I am trying to use automatic button hole and it keeps beeping and showin bl?
Ok, so all the credit goes to this website http://www.burdastyle.com/howtos/show/95
Photo 7 shows a buttonhole lever that comes down and contacts the auto buttonhole presser foot. The machine manual is a little vague about this in the section about buttonholes. At the point when it shows the lever being pulled down, the manual should reference the part number in the list of part names in section 1, and it would have been easier for me not to have mistaken that lever with the stop on the side of the presser foot that the lever sits against . . . . that also kinda looks like a lever! Probably a no-brainer for someone who does this all the time, but for a noobie like me . . . .I'm glad I found the website above. So . . . .the machine is now making perfect buttonholes 30 seconds after finding the butonhole lever! Groovy!
John and Linda
Buttonhole lever pulled down (presser foot not attached)
e011ff3.jpg Buttonhole lever resting against stop on presser foot
(Photos from burdastyle.com)
Jan 07, 2009 | Kenmore 19110 Computerized Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
177 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
