In some cases you have to turn it OFF/ON few times to get the copier to the ready mode.-------- So try to turn copier OFF and ON 7 to 8 timers and see if that helps.----------- Every time you off and and on the printer see if its gets to ready mode , if not then again off and on.------- Try this approx 7 to 8 times and see.---------- But if this is not helping that problem relates to low heat .In the copier there is a fuser assembly.This assembly heats inside.When the assembly reach at certain heat temperature, the printer gets to ready mode.-------- In your copier this fuser assembly is not heating to required level, so its just showing this " Wait Warming Up" message on display.---------- So the first possibility for this problem is fuser assembly.---------- Other possibility is heating lamps.---------- The 281c has lamps, not IH coil. In fact, it has 2 lamps, 1 heats middle, and 1 heats outer edges of UFR. My guess is one of your lamps is not coming on. If it's not a burned out lamp, it's the switching regulator that controls the lamp. Bad news... requires LGC bd replacement. The fuser is meeting the requirements for warming up ( certain temp within certain time frame) but since both lamps aren't coming on it never fully heats up.The edge temp thermister only shuts off the lamp when temp exceeds 230 degrees.But in your case this lamps are not heating the fuser to required temperature.,-------- Mostly this are the possible cause of the problem, and fuser assembly and lamps needs to be inspected.------- The copier needs to be taken apart to inspect this parts and tested with meter.To confirm the fault.------------ This will help.Thanks.Helpmech.
Hi, Thanks for using fixya..
Try replacing that drivers you install and let me know what happened..
Thanks..
reloaded driver. Shut down computer and printer. Started up. Printer still shows "Wait Warming Up". Unfortunately, this was not the solution.
I will check the 2 lamps. What is "LGC bd replacement"?
Thanks,
Rick Root
