Question about RCA RS2044 Shelf System
No Remote System goes wild when batteries are low. Replacing with new batteries, the remote will not work. Cannot adjust volume, etc.
    Scholar:
  • 48 Answers
The remote have to work with new batteries. You can check the board where the components are mounted and resoled any that look bad. In your case it could caused by a leaky diodes or a bad solder. All can be replaced at a local electronic or hardware store and they're easy to replace Possible batteries problems: 1 batteries are not making contact properly inside the remote. Test by cleaning connections of the batteries and the remote. 2 battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. 3 batteries are bad and are not actually recharging. test by using other batteries if possible. 4 other, unknown, internal remote problem. buy a new one.
Posted on Dec 28, 2005
My remote works fine except for the volume control to the receiver(HTR5440). How can I set this for response?
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-5440_black__u/
a good start would be a glance at the owners manual
this will help
perhaps you have a faulty remote
perhaps it got banged and needs the insides soldered like the IR diode at the top end
i see you mention it isnt working
so try another or take the remote to an electronics buddy who can click it open and check for a bad solder or etc...
Dec 09, 2014 | Yamaha Audio Players & Recorders
Can not adjust volume
dere may bea problem wid d battery ,try replacing the battery ...if the laptop is in warranty den get d remote repaired ... although u can repair it urself by opening d remote and rubbing d contacts wid some metal
Feb 09, 2010 | HP Mobile Remote Control For Pavilion...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
My tv turned on on its own and does not respond to the remote, even after replacing the batteries. Furthermore, the volume goes up to 100 and down to zero on its own and the remote is not able to control...
check remote first,how to check remote switch on your camera phone point to camera lens,when press any key check screen light glow,you sure r/c ok.next check reciver eye of tv
Jun 27, 2009 | LG 32LC7D Television
Remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
May 31, 2009 | 1996 Chevrolet Camaro
Sound problems
I'm not like an electrical engineer or anything, but it sounds to me that there are some problems with the circuitry that operates the sytem (the circuitry in the subwoofer/built-in amp inside the subwoofer). As for the volume control, have you adjusted it from the remote and from the controls right on the front of the subwoofer? If you only tried adjusting it from the remote, then you probably need a new remote (if you can get a new remote; I don't think most remotes work with Durabrand). If you tried adjusting it from the controls on the subwoofer unit, then the subwoofer's circuitry probably needs to be replaced.
May 12, 2008 | Durabrand HT-3915 System
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
RCA RS2044 Shelf System Logo
125 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
