Question about BenQ FP71G 17" LCD Monitor
Benq fp71g mi monitor no tiene alta tensi?n, se enciende el led de encendido a verde pero es como si no hubiera alta tensi?n para iluminar la pantalla a pesar que se puede ver en la oscuridad, el logo de Benq difuminado, agradecer?a mucho una orientaci?n. Saludos cordiales. enriquetroy@yahoo.es
viziks
  • 220 Answers
SOURCE: Benq FP71G+S NOt starting.
yes Benq does have a 3 year warranty.
Samir
Posted on Feb 27, 2008
Marrie
  • 563 Answers
SOURCE: Favi31
English ????
Posted on May 13, 2008
viziks
  • 220 Answers
SOURCE: Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
viziks@gmail.com
Posted on Sep 12, 2008
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
SOURCE: Benq FP71G monitor screen displays momentarity on
check your power supply and power cable and check your monitor cable if its not damaged..or try your monitor to another computer..
Posted on Jan 19, 2010
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
No enciende el monitor
Hi
hola
tengo el mismo problema. parece que este es el vga.
trate de poner una tarjeta vga en la ranura vga y ver si la pantalla se enciende.
 dígame lo que pasa entonces.
envíeme  email en este adress:
camlamm@yahoo.com
Sep 03, 2008 | ASUS P5B-VM DO Motherboard
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mi problema esque mi philips gogear no ensinde
Tienes el mismo problema si lo conectas a tu pc?
Jun 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Julio cesar vazquez : tellvaz@yahoo.com
in my monitor the two lines r coming can u explain how to solve
May 13, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
108 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
