Question about Gateway Projector 210 Multimedia Projector
Won't turn on
I connect power to the 210. The stand by light flashes slow. I press the standby button, the standby light glows steady and it begins to power up and there is a small about of light coming from the lamp. After about 8 seconds the lamp goes out, the fan spins like it is cooling down and the indicator light flashes fast. After three minutes the unit goes back into ready mode but I can't get it to turn on.
  • gilly15215 Dec 11, 2007
    I have the same problem, opened it up and cleaned it up but wasn't sure what I was looking for. Any more help???
  • aldouszool Feb 18, 2008
    i also have the same problem with the same gateway 210 projector. I opened it and can't see a fuse. I need help, I've been searching for weeks
    Thank in advance
    Problem Solver:
  • 7 Answers
If the projector starts to output light then goes out that is the lamp. Hopefully you got a good price for the projector the lamp will be around $300. Before you replace the lamp you may try blowing out the projector, dust will cause shut down as an overheat protection. This may at least get it to turn on long enough to go through the menu and see how many hours are on the lamp. Be sure to reset the lamp counter if you do replace the lamp. If the fan blows and the indicators turn on the projector is probably functional.
Posted on Apr 07, 2008
    Scholar:
  • 48 Answers
If you're NOT still under warrantee you should at least open the projector and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the remote to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your projector serviced. good luck!
Posted on Dec 28, 2005
Tv is stuck on standby. The standby light (red) is steady and when I press the STANDBY button, nothing happens. no response or flashing light.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 11, 2015 | Televison & Video
Wt8951nd
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
Feb 08, 2014 | Computers & Internet
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My HP C4280 makes a loud clicking noise before it begins to print
Try perform these steps as --->
Please perform these steps as please disconnect the power cable and press the power key for 30 seconds and at the same time connect the power cable then turn on the printer and let me know the status
And also perform this steps as 1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold On and Copies button.
When only the On light is flashing, release the buttons.
When the On light is steady, 1. Disconnect and then reconnect the power cord.
When the On light is steady, the reset is complete. the reset is complete.
If the printer works then good
Otherwise Hardware issue
Jul 30, 2010 | HP Photosmart C4280 All-in-One InkJet...
THe pc gives a steady orange light when power
Sounds like its in either standby or hibernate. Try unplugging it if it wont power on, press the power button, wait for 2 minutes then plugging it back in then turn it on. Afterwards, go into power managment, and find where it asks what do when you press your power button change from hibernate/standby to ask what to do.
Mar 07, 2010 | Dell OptiPlex GX520 PC Desktop
Stand by light on but thats all
if it does nothing when you push the standby button to make it play the most common problem is the power standby sw is bad. do you know how to use a miltimeter if so test the voltage through the swithc when you press the button.
Oct 14, 2007 | Coby DVD-207 Portable DVD Player
Gateway Projector 210 Multimedia Projector Logo
287 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
