Xerox 5334 fault code U4-1
The display is saying 'call for service' and the current fault code is U4-1. I have check for paper jam, and cannot find any. What else could U4-1 mean?
    Problem Solver:
  • 7 Answers
Reset the fault code first as follow:
Enter in diagnostic mode
Enter 20-3 and press 0 then press start again .
Hope it will solve if not done check the heater lamp continuty if found fault replace same.
Posted on Sep 20, 2008
U4-1 is a resetable fault code.Switch off press and hold 0 and switch On,Touch Routines tab, Enter 20 and start print,3 and start print,0 start print.Test the copier. But the problem is why has the copier produced this code.It could be that the thermister (which monitors the heat) and should be in contact, and riding ontop of the Heat Roller, has become disloged sending the copier into overheat condition.So first Switch Off the power to the copier, then remove the Web Assy 2 bolts on top of the fuser.Look on the R/H side of the Heat Roller the Thermister should be resting on the heat roller clipped under the metal bracket.If OK the next thing to check is the Over Heat Fuse in the center of the metal bracket (Has 3 AC wires connected to it 2 on the left and 1 on the right,pull off the one to the right and test across the fuse for continuity.If ok,It could be the Fuser heat rod has blown. regards exxerox
Posted on Jan 18, 2011
What does Fault code 078-211 mean on Xerox copier D110?
Found in the Administrator's Guide:
078-210 / 078-211
[Cause] Tray 6 (HCF) malfunction
[Remedy] Contact our Customer Support Center
Before calling, check for paper jam or small pieces of paper in and around Tray 6. There may be a piece jammed around a sensor that is throwing the error,
Mar 17, 2015 | Xerox Office Equipment & Supplies
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Xerox phaser 8500 paper jam
Before you clear the paper out, If you press the question mark button (?) it will display the Jam Code which will narrow down what kind of jam you have. You can look it up if you can get access to a service manual.
Oddly, the most common jams aren't caused by rollers and need a DM camshaft 020K14801 changed instead. If you have jams right at the tray then get the roller kit 604K42200 after all.
Good luck ...Whit at
Aug 18, 2013 | Xerox Phaser 8500/DN Printer
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 5334 says it has a paper jam but i don't see one
A paper jam on this machine can be several things. Not seeing the machine, it can be in the fuser area, There is one switch there that can cause a jam. if there is a acornidan jam there the paper has to be removed.
The machine can have a bad cartrige, the pr belt maybe be a cause of the jam espeically if there is a U-7 code. (A false jam) The pr belt timing hole cannot be read by the timing hole sensor. If this is the cause, a broken mount on the copy cartridge unit can cause this problem. The cartridge reciever unit needs to be replaced.
In the registration area there is a jam sensor that can cause this type of jam. If it fell out of place, or the magnet on the back of the acutuator arm has developer beads, can cause the machine to get a jam signal.
Oct 12, 2009 | Xerox Office Equipment & Supplies
Xerox 5334 service manual
i don't think so because the manual is protected by laptop xerox
Apr 09, 2009 | Xerox 5100 Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
Repair of xerox copier 5334
the sensor board of trays is abnormal check it
Sep 12, 2007 | Ricoh Aficio 450 Copier
1,471 people viewed this question
