Internet Connection I have satellite internet connection with a router. My husband's Gateway laptop has no issues connecting but my Toshiba will not. I have no idea how to fix it.
    Scholar:
  • 81 Answers
Try going into your Run program and type in cmd.exe. Once your MS-DOS comes up, type in ipconfig/ release. After that, then when the page runs and stops, type in ipconfig/ renew. After that, see if your computer will connect to the internet. Also, make sure that your wireless password, if you are using any, is correct.
Posted on Sep 07, 2008
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
My toshiba satellite laptop want connect tothe internet
It could be a couple things: 1. Try connecting using the wired connection if you can. If it works, then problem most likely with wireless. 2. Try connecting wirelessly maybe using a public WIFI hotspot or a friend's connection. That will rule out your router. 3. It could be a browser issue: Start / Run / Inetcpl.cpl and then check the Internet settings. Make sure there are no proxy settings set.
Feb 20, 2011 | Toshiba Satellite A105-S4022 - Laptop...
My Toshiba Satellite L305-S5921 won't connect wireless or wired to my internet it shows the net works and signals and can be connected to the router but ends up with local or limited service I've reset the...
Try disconnect the router and connect your laptop to the dsl modem. If there is connection then the router may have problems. If the problem persists then go to toshiba service center. They will certainly solve your problem. It might be that there are problems on hardware or drivers.
Jan 30, 2011 | Toshiba Satellite L305-S5921 Notebook
My toshiba satellite laptop won't connect wirelessly to Bigpond home network gateway. Bigpond reckon it's a toshiba problem
As a general test, see if you can ping the "router's configuration URL IP address". To do that go to a command prompt(DOS Prompt) and type in ping and the routers IP. If you get replies you are OK conencting as far as the router. Next try PINGing to www.yahoo.com or www.google.com. If you get replies you are OK conencting as far as the Internet. If not try sending a ping to their IP(the numbered) address. If you get replies you are OK conencting as far as the Internet, but you have a DNS issue. Big Pond can help you with that.
Nov 20, 2009 | Toshiba Satellite Pro P300 Notebook
I bought this router 2 days ago. I pluged in the phone socket (with micro filter), and into mains,it worked perfectly on my daughters' (each daughter has a laptop - all work)laptops, and one of my desktop...
1) Make sure there is no low-pass filter from the phone line to the wall - it should be directly connected.
2) The laptop issue has nothing to do with the wireless router if it's actually connected. Try pinging the router. Open the command prompt. type ipconfig. Look at the laptop's IP address and the gateway. Try pinging the gateway (ie ping 192.168.1.1). If the ping works, the connection is fine.
3) Can you open a browser window but not connect to a web page? This is due to a connectivity issue. If you can't even open a web page for whatever reason, its a problem with the laptop, not the connection. Hope this helps.
Nov 08, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Cannot get internet from router to
If I understand correctly you want to use the router as a gateway for an sat. receiver.
This Netgear router can be connected to devices that has TCP/IP connections (RJ45) ports or wireless IEEE 803.11 b/g, and that can get the IP address statically or from DHCP (router). Toshiba can do that and therefore it is working fine. If sat.receiver is not device that can behave as a PC (processor etc.) it can not get IP address and router can not "see" that device, therefore router can not let "something invisible" to connect to the internet.
Sep 07, 2009 | Computers & Internet
Lost connection to the Internet - Laptop & XBox Live
2 anti-virus on 1 computer will conflict with one another. uninstall your mcafee first then go to AVG's site if you need help with the firewall. http://www.avg.com/faq.keyw-firewall#tba2
May 12, 2009 | Toshiba Satellite Pro L300-EZ1004X...
Need to set up wireless for toshiba A105-S-4034
If you have installed the AT&T software, you should be able to use that application to connect to the Internet. Are you using a USB gateway or do you have a stand-alone gateway?
If you have the USB type, install the software first and then connect the USB gateway, Click on the software app to start the Internet connection. AT&T info will show a tab for GSx and one for Wireless. As long as you have a subscription, I would use the GSx tab, otherwise, select the wireless tab and connect to your gateway or any other wireless router that you have access to. Good Luck.
Feb 03, 2009 | Toshiba Satellite A105 Notebook
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Laptop wireless connection
assuming you have set up the router to enable DHCP which automatically detects pc's and assigns an automatic ip address, and assuming you are using XP and not Vista, although the workthrough is similair; go to open internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked, then apply and exit IE
Next go to control panel>network connections, double click your wireless connection icon, select the TCP/IP line and click properties, then make sure obtain an ip address automatically is ticked, apply it ok, then open IE again and click the refresh button a few times.
Sep 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
