Question about Mitsubishi WT-46807 46" Rear Projection Television
Turns on but no picture, just black, worth repairing? Mitsubishi 46" projection
I have a Mitsubishi wt-46807 projection 46". Few weeks back turned on and no picture just black, light on front on showing its powered. Thought ****, left alone couple day later worked fine. Then same thing happened but only on one of my inputs (for xbox) screen on but all scrambled, however worked fine on different input for DVD. Then only worked on DVD, now turns on and pure black, can hear a little fuzz like speakers working and light is on like it is powered up. This TV is a beast and weighs like 500lbs, near impossible to move or relocate, is it worth fixing (cost effective) or is it time to roll it down a hill and upgrade? HELP?!?!
thanks you so much for your time
Andy
    Sergeant:
    Champion:
  • 227 Answers
You have some bad caps, the only problem is that could be a lot of them.
Posted on Oct 01, 2008
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I would like to get a copy of the instructions to replace or resolder the convergance IC's on a Mitsubishi WT-46807 from SD Tech please thanks, DT
DT? I am becoming famous with these instructions--having done the repair hundreds of times and getting asked the same question here by many people I composed the step by step instructions.
Once you get the instructions all I would ask is you rate them with a vote on this question.
SD TECH
Jan 25, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Does the Mitsubishi WT-46807 need a converter box to receive a HD signal?
Yes, this model only has one HD input--it is the one marked on the back of the set as DTV---you need to hook a box for HD to that input.
SD TECH
Oct 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Will not show picture when turned on
replace the convergence ic's i beleive that's your problem
good luck
caypianan@yahoo.com
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
