Question about Jensen CD4610 CD Player
Faceplate malfunctioning and scanning repeatedly
When the radio turns on, none of the buttons, save maybe the menu button, become responsive and the radio or whichever input continually scans. "Manual Seek" appears on the screen and nothing can be done. Sometimes, the remote will work, but nothing else does. The radio also automatically turns on when power is supplied, instead of waiting to have the power button pressed.
    Champion:
  • 277 Answers
Hi this meens the wohle panel is squashed on its buttons the seek button is main 1 and wont let anything work besides it take out the button release the screws all the way jiggle it a little bit, or even take a look inside that nothing is broke or loose tightened the screws but not hard(soo it wont happen again) good luck
Posted on Feb 26, 2006
RADIO CAR CLOCK SCREEN ONLY INDICATING -- -- HOW DO I PUT FIGURES
Try this...it is for the 2000 series but should work for all KDCs:
Hold the "Menu" button for about one second to enter the Kenwood's menu. This button is located on the right side of the faceplate.
Push "AM" or "FM" until the Kenwood's screen shows "Clk Adjust."
Hold the "Right Seek" button for about two seconds. The clock will start to blink. It's now ready to be set.
Push the "AM" button repeatedly to increase the hour. If you want to decrease the hour, push the "FM" button.
Push the "Right Seek" button to increase the minute. Push the "Left Seek" button to decrease the minute. Push "Menu" to set the time.
Sep 21, 2011 | Kenwood KDC-W3037A CD-receiver,...
Motorola Talkabout FV300 channel keeps scanning 1-22 very fast and will not stop.
The instructions for FV300 are a little incomplete. When scanning the Z symbol is already showing. You must press the menu button 6 times until the Z shows up again. In the lower left of the screen you'll see ON. Now push the + or - key and you'll see OFF in the lower left of the screen. If you delay too long scanning will start again and then you must repeat the above steps.
Sep 08, 2011 | Motorola Talkabout FV300 Two Way Radio
My KD-LH810 turns on and plays the cd that is in it but the faceplate does not come on and it continues to play the cd - I cant turn it on or off and none of the other buttons work on the faceplate work so...
wipe the connection where the face connects at i had the same problem and it works fine after cleaning the connection and i will guess the power light itself is still lights up and no other button lights or the screen itself if that is correct then u most likely just have moisture in the connections try wiping it with a dry soft cloth
Oct 27, 2010 | JVC KD-LH810 CD Player
Only playing a few sec of the song and then going to the next song
your player is in the "intro mode" , to change this follow these steps.
  1. play a song and while the song is playing
  2. press the menu/mode button and then with repeat highlighted,
  3. press the menu/mode button again to enter the repeat settings sub-menu
  4. press the right/left keys to change and highlight the repeat setting from "intro" to the mode of your choice like "repeat all"
  5. press the menu/mode key to save your setting...
Since this is a free answer,please take the time to rate my response,thanks.
Oct 09, 2010 | Toymax Impecca MP-1825 MP3 Player
None of the buttons on the faceplate seem to work except OFF. The remote works and still can control all functions on the radio. I have read the manual and don't see anything about the faceplate locking or...
check the gold contacts on the back of the face and the unit also check the release mechanism theres a little black button (not the reset) that when face is pressed up against it it activates power to the gold contacts thus powering the buttons
Dec 14, 2009 | Sony XPLOD CDX-GT200 CD Player
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
Jan 09, 2009 | Aiwa CDC-X504MP CD Player
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Jensen CD4610 CD Player Logo
116 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
