Question about Matsonic MS9317E Motherboard
Usb1 when i tried to connect the usb1 to my motherboard there's nothings happed
  • 119 Answers
Get an USB 2.0 card..sometimes the motherboards usb doesn't work
Go here to get a good one this one will do usb and firewire..
Good luck
Posted on Jan 19, 2009
How to install frontal usb on s381-m motherboard
There will be a 7 pin connection, probably around the PCI slots, on the motherboard. There will be some kind of label printed on the motherboard which says FRTUSB, USB1, USB, ect...
Mar 17, 2011 | Tekram S381 M Motherboard
I had a compaq_pesario_CQ50 110us, when i press srt botton its fan run but nothing haps, no boot nothing,, pls help
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 23, 2010 | HP Compaq Presario CQ50-110US Laptop
Usb port not supported
What is that is not recognized, the device or the port?
Please go into your Device Manager and delete all references to USB ... you will find them listed at the bottom. Reboot. Windows will install what it needs.
If it still doesn't work, are your devices USB1 or USB2? Are they big power hungry devices? Is your independent USB power supply operating?
If still nothing, you may consier adding a USB PCi card.
Thanks for your interest in FixYa.com
Mar 01, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Feb 08, 2010 | MSI K8MM-V Motherboard
Try to hook up front side usb but need to know were to start powerwire in the yellow socket? msi kt4av mobo help please
The front side USB should connect to USB pins located towards the bottom of the motherboard. Usually you will see a "USB1" labeled next to the pins that you would connect the wires to.
I tried looking up a manual for your particular motherboard, but there doesn't seem to be any posted online...That are I just got a little lazy while using google. (probably the latter...)
You'll get more info about the motherboard from here: http://us.msi.com/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=552#
Jan 08, 2010 | MSI KT4AV-L Motherboard
How do i connect my extrernal usb ports
Just look at your motherboard you will see soket with 9 pin with written word USB1 or 2 so connect that soket with your external usb cable. it will work
Aug 17, 2009 | MSI 865GVM2-LS Motherboard
I would like to know how to connect my front usb port on the motherboard
There should be some slots on the MB that say either USB0, USB1 or 1394. It is the connector with 9 pins, one of the corners missing.
Looks like
Apr 28, 2009 | MSI PM8M-V Motherboard
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
Melfunctioning of USB port
possibly have a usb 2 device in a usb1 port.
try updating driver for printer
more help may be available if you post more details like printer model
Jul 05, 2008 | Intel Computers & Internet
Trying to set up front usb ports on asus p4p800se
Find usb pin in the boad " USB1 & USB 2" You can see five pins in the board composed of two lines. connect the cable in the line composed of four pins. from left. VCC, Data-2 , Data+2, grnd2. After connecting try a Usb mouse if the USB mouse function well then connection is correct.
Jan 06, 2008 | ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA)...
Matsonic MS9317E Motherboard Logo
125 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
