Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Hot cord the cord on my vacuum cleaner has been getting very hot the heat is from one end to the other incuding the plug and also where the cord exits the back of the canister please help I love this vacuum cleaner it has been faithful to me for over 15 years!
  • 125 Answers
Likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Posted on Dec 03, 2008
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
It would be the easiest way, attaching a male plug to the end of the severed cord so it can be used with an extension from the power outlet. Safe too if you duplicate the wires in the old portion, as the cleaner may or may not be earthed.
Oct 13, 2014 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    While vacuuming, the sweeper shut off. Is there a reset? It wasn't hot and I've only had the sweeper less than a year. I had cleaned out the dirt before I started.
    UNPLUG
    Now check your cord to see if you have any breaks.
    If you don't see anything then try feeling the cord for breaks.
    Still can't find anything? Did you check both ends?
    Does the cord look good going in to the Vacuum?
    How's the plug look?
    Have you tried pluging a lamp or something you know works in to the outlet you are useing? This will let you know if you just need to reset a breaker, switch or GFI. ( The Hoover Company Consumer Response Center at 1-800-944-9200 M-F 8 AM - 7 PM EST )
    May 18, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
    Power goes on and off.
    It could be three different things- or one or more of these three, but more than likely just one.
    1- a bad cord or plug end
    2- a bad switch
    3- a motor brush is losing contact due to poor pressure due to the carbon brush being worn- of the two motor brushes, their length is normally sufficient to last for years with trouble free service. However, if a vacuum is neglected, as in the filters never cleaned or replaced ( use 10/ $2.99 electrostatic register vent filters from any home store's furnace filter section. Cut to fit, and in the case of the Hepa filters, if you have a dusty family you'll go broke changing these so just cut your electrostatic ones and maybe stack a layer or two, but since they are cheap be liberal and change often). What happens with dirty neglected vacuums is they overheat causing the motor brushes to glaze the copper commutator they ride on and eventually wear out the carbon. The added brush dust cakes up and acts as an abrasive.
    Alright, so it's not an issue of neglect or jerked on cords? Well, unfortunately several manufactures have lately installed somewhat inferior switches on their vacuums by way of saving a few cents in manufacturing costs. The amperage ratings on the switches are rated just above the typical 12 amp motor ratings on the vacs motor. In real world use though the strains of suction resistance and cord resistance caused by ultra thin copper wire in the cord add up to extra heat at the switches terminals. The plastic in the switch will get very hot as you vacuum and when you flip the switch off each time you finish vacuuming it literally shifts the switching contacts into positions a little more distorted from their original setting. Arcing is the next thing that happens and then its a heated plug end.
    That's the story of how a vacuum cleaner works when it's stressed and strained. Ironically when all of this goes on the bearings also overheat due to the arcing motor brushes. And because the belt for the roller is on this motor as well, when you shut the vac off the belt will heat up and even melt slightly. Then when you go to vacuum again the belt will vibrate causing more damage...
    This is why bag vacuums are better.
    Better yet, get a Rainbow D4 and ALWAYS ALWAYS ALWAYS spin the separator by hand to assure the brushes are not sticking before powering it up. The D4 is the best vacuum ever made. The Eureka Vibragroomer is the best upright ever made.
    Oct 07, 2009 | Vacuums
    Hoover Steam Cleaner F6024-900 does not turn on when plugged in to working outlet.
    You may have something simple like a bad plug end piece on the power cord. try it in another socket if it still doesnt work you may have to replace the plug.
    The most stressed point on a vacume is on the power plug and cord because it gets pulled and twisted a lot.
    Jul 14, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Dyson 07 plug gets very hot after prolonged vacuuming
    Electrical current passes through the electric cord and plug - it will get warm, that's normal. If the problem is worse where you smell an electrical burning smell, only an authorized dealer can fit a new power cord to your vacuum cleaner. Call the Dyson helpline, they will let you know who the closest repair dealer in your area is.
    Jul 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    The automatic cable rewind on my Morphy Richards pod vacuum cleaner keeps retracting. I'd rather it didn't work at all than be constantly pulling out the cord. Is there any way in to fix it or disable it?
    Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
    Jun 19, 2009 | Miele S251i Plus Bagged Canister Vacuum
    Broken electrical cord
    The belt can e replaced but I recommend you should take it to your local vacuum cleaner service center. They may even be able to fit a new plug on the end for you if the damage is at the plug end.
    Mar 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Electrolux 5500
    Depends on which model you have, but most of them you take off the center section, then you cab get to the 2 screws on top , and there is a screw on the bottom, then the back end will pull off. But I wouldn't try taking the cord reel apart, if that spring lets go while you are doing that, it could be dangerous. Also make sure that it isn't plugged in.
    Dec 22, 2007 | Electrolux Lux 5500 Canister Vacuum
    Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
    876 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
