Question about Microsoft Multimedia Internet Keyboard PS/2 HK-810
Method to Remap Global Hotkeys
I've found a method to remap the normal hotkeys using TweakUI, but I also know that certain programs (such as Winamp) allow the use of Shift+Hotkey. I'd like to specify Shift+Media as a different media player if possible.
  • 14 Answers
SOURCE: Hotkey logs into Outlook Email but I use Windows Mail in Vista
go into control panel and go to the controllers/keyboards selection and change the setting for hotkeys. it should display the name of your keyboard.
Posted on Apr 03, 2009
0 characters
1 Points
Ive lost my hotkeys on my keyboard
Sounds like your keyboard driver has either stopped working or has been removed. Keyboards will function as normal without specific drivers but hotkeys etc. wont work. Look at the manufactures web site for keyboard drivers, usually they are pretty good at providing the downloads. without them installed correctly hotkeys will not work. Once installed run the software and check the keys assignments.
Nov 24, 2013 | Keyboards & Mice
I can not disable my red alt key functions
MapKeyboard - MapKeyboard is a free program to remap your keyboard. Using MapKeyboard, you can alter any key on your keyboard to function as a different one or altogether disable it as well.
This is an essential tool for laptop users and other people with keyboards whose keys differ from the standard 101 keyboard layout. The changes made are universal across all applications & games and best of all, MapKeyboard does not even need to be actively loaded in memory.
MapKeyboard enables you to remap your keyboard and alter any key to function as a different one or optionally disable it as well.
The program can be quite useful for laptop users and people with keyboards that differ from the standard
hope this helps
Jun 30, 2012 | Toshiba New US Laptop Keyboard For...
How do I reverse selections on number pad? I presume it is achieved with a key stroke like the caps lock. Which one?
I am not clear on what you want to do ... you don't want to put the 1 where the 7 is ... do you?
You can set your key pad to be numbers or you can use the other features listed on the keys, To change between numbers and features, you press the "Num Lock" key which is normally just above the 7 key.
If you do want to put the 1 where the 7 in, for example, you will have to remap your keyboard. And this is entirely possible ... I am not going into that detail here ... it is beyond the scope of what happens here normally. You can find instructions for remapping from Dell or any other fine computer manufacturer. Also, if you want to pursue this, you could 'goggle' remap my keyboard' for instructions.
Thanks for your question at
Feb 04, 2011 | Dell 0Y3740 Keyboard
Dell usb keyboard rt7d10, volume, etc buttons not working in windows 7 64 bit.
I found a program here that enables the buttons, you have to put the program in your startup and it will map the 7 hotkeys (7hk) to their functions.
Good Luck!
Aug 11, 2010 | Dell RT7D10 Keyboard
My media player keys on razer tarantula keyboard
after i checked the preferences in winamp i found out my hotkeys were not enabled so thats why they were not working. So if you have the same problem go to preferences -Global hotkeys and check the 2nd box
Mar 18, 2010 | Razer Tarantula RZ03-00070100-R2U1
Shift key shuts down my computer
Someone is probably playing a prank on you. Disable the services one by one until you find the program that is assigning those programs hotkeys so programs can't run with hotkeys.
Jun 07, 2009 | HP Keyboards & Mice
Hot key of the keyboazrd aren't working
Check your system configuration and see if the hotkeys are activavted , also check bios as some have hotkeys switches there also .. if unsure refer to help in your windows directory and search for hotkeys then it should give you all the information you need .
hope this helps .... Regards Vortash
May 12, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Multimedia buttons(stop, start) etc not functioning
if you use winamp go to preferences - global hotkeys and check the 2nd box (enabled) i had this problem aswell but after i checked the preferences and did what i just told you it works fine now ^^ and if you are using mediaplayer try to search for the hotkey options (i am pretty sure that mp has 1 aswell)
Sep 30, 2008 | Keyboards & Mice
Euro key
You can try the free KeyTweak program to remap the euro key or just plain disable it. To remap the key means changing the function, for example you could make the euro key into the Caps Lock key. DOWNLOAD:
Jan 01, 2008 | Acer NSK8458AN Keyboard
Keyboards & Mice Logo
26 people viewed this question
Top Microsoft Keyboards & Mice Experts
micky dee
Are you a Microsoft Keyboard and Mice Expert? Answer questions, earn points and help others
