Question about Tappan Ovens
Tappan double oven range TG0356BHW3
I do not have a manuel for this oven and am selling the house. where can I purchase a manuel?
3 Suggested Answers
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Posted on Oct 30, 2008
EllaWatson25
  • 725 Answers
SOURCE: What does an F3 code mean on a Tappan
This is your oven temperature sensor on your Tappan Oven.
T
hese codes are designed to troubleshoot your appliances and prevent further electronic issues from happening to your unit.
It is a simple repair that you can repair yourself and you can save a ton of money, also!
Once this part has been replaced, you oven should close properly and work just fine.
Posted on Oct 20, 2009
316080102 dim
Oven control board is not working # 316080102. You would need to get it repaired as it is no longer available for purchase.
I would recommend a fast, easy and affordable vendor named Partsimple.com. Partsimple has high level of expertise in control board repairing. many vendors do purchase from them then sell as if their own product.
I have also attached a direct link for reference.
http://www.partsimple.com/316080102-frg-r-12.html
Frigidaire Kenmore Tappan Range Control Board Repair Service 316080102
Jan 27, 2014 | Ovens
How do you remove electric elements
read owners manuel. no manuel? call store that sells these stoves.
Apr 21, 2013 | Tappan Ovens
The upper oven on my Tappan Gas double oven is to hot. When set to 300 it ranges up to 350, but when set to 375 it goes up close to 500. I tried to adjust the knob setting but that did not help any...
Sorry to read about your problem, I hope this helps you out.
sounds like you just have a defective heat probe, you did not give a exact model number, which we will need to further help you...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Tappan Ovens
I did a self clean on my tappan electric oven; cant get the door to open.... what can i do?
MaryAnn, If you try to push the locking lever/handle towards the "lock" position first, then pull it back towards the open position, it should unlock for you.
However if that doesn't work, you can turn off the breaker for the electric range, in most electric panels, it is marked as "Range" or "Stove" but is typically a double pole 50 Amp Breaker (It takes up 2 spaces). If you look at the handles of the breakers, you should be able to see the numbers "50" on the handle.
Once you turn off the power, you should be able to unlock the oven. Some ranges require that the power be on in order to unlock it, but first try to open it with the power turned off, and it that doesn't work, turn the breaker back on and the door should be able to be unlocked.
Remember that it will take a little bit of effort to get the door to unlock in some cases, so give it a good tug.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Tappan Ovens
What does an F3 code mean on a Tappan oven/electric range? The lock on the oven door is sticking out not allowing me to shut the oven door all the way.
T
Oct 19, 2009 | Tappan 30IN ELEC IGNa Oven
Looking fior a manual for a Tappan Continental Electric Range
go to frigidaire .com they make tappan. then go to customer service , then go to manuels put in your model # then it should give you the manuel. hope you find it.
Sep 17, 2009 | Ovens
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
100 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Craig Butler
Craig Butler
Are you a Tappan Oven Expert? Answer questions, earn points and help others
