Question about E-Machines eMachines Desktop PC
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
I have Emachine T2958 with 80 gig hard drive. I added another 80 gig hard drive some time ago, worked fine. Recently MS installed Service pack 3, it crashed my puter. I ended up re-installing Windows, whole thing. Everything is fine now, even have SP3 in and working fine, but computer thinks my extra 80 gig hard drive is a disk drive. I took wires off hard drive (unplugged it more or less) and it's still listed as a disk drife (F). ls there a way I can get into BIOS (like in the old days) and change the designation?
I am running Windows XP, home edition
leonard_lv@yahoo.com
  • leonard_lv Sep 07, 2008
    Came close, learned a lot, but it seems that the computer "sees" both hard drives, the main one (drive 0) is "C", then the extra one is drive 1, with no letter assigned. It used to be drive F... now it shows I think it's drive 2 as "F", but like a USB port! Thanks for trying though, I appreciate it!
    Genius:
  • 1,056 Answers
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Posted on Sep 06, 2008
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
Jul 07, 2012 | Apple Computers & Internet
My computer has crashed and i do not have a resrtore disks one did not come with my purchase and i do not know what to do I am in school and i need to take my finals please help!!!
if your pc didnt come with an os disc you might have a recovery portition on your hard drive .try restarting and push f10 if no go post back with os and I will see what can be done.
Jun 20, 2011 | E-Machines eMachines Desktop PC
Hard drive on an eMachine computer desktop has crashed. Computer won't boot. Is there anyway to get files off the crashed hard drive?
take the hard drive to a local computer guru... recovery will depend on what caused the crash, and what has happened since then. Basically, he or she will need to try to boot your hard drive with another tower, or pull all the info directly from the disks themselves. If you had to ask this question, you're gonna need help to fix it.... Sorry.
Aug 09, 2010 | E-Machines eMachines Desktop PC
Emachine t5026 boots only with os disk in drive
Emachines don't use the cable select properties very well. Change your drive to Master, reformat and reinstall the operatiing system.
Apr 10, 2009 | E-Machines (T2958) PC Desktop
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
Need to add hard drive and memory to emachine tower 333
Okay, this is what you do, I don't really think that Win 98 supports dual HDDs, but I think I can help.
If you have a IDE Dual Cable (plug into the Motherboard and have two connectors attached), Do you see the mini plug by the connector on the HDDs? (Usually white or different color) on the Original HDD, put the miniplug to "Master" and the second (added) HDD to "Slave" or you may be able to use the "Select" on both.
What I do recommend though is going ahead and burning all of your precious data to CDs and buying a newer HDD.
Instead of 4 Gigs, get something around 80 Gigs.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2948583&CatId=134
If you give me the motherboard specifications, you may be able to update your RAM to 128-256 MB
Mar 09, 2009 | Microsoft Windows 98 Second Edition for PC
Crashed hard drive on emachines T5026
Pardon me, but NO! The statement, "two things are responsible for booting up computer RAM and Hard Drive" is simply not true.
A hard drive crash COULD cause the symptoms you describe, but that is more indicative of a virus infection. When you say the XP reinstallation disk would not start it exactly how did you use that disk? Attempt to use the repair console? Boot directly from the disk? Attempt reinstallation of the whole operating system? If you attempted reinstallation, do you also have the specific drivers for all of the components E-Machines used when they built your computer (you will need at least some of them.)
Post again with some more details about how you used the reinstallation disk.
Feb 24, 2009 | E-Machines eMachines Desktop PC
EMachine T3025/Best Buy
get simple windows xp you just have to format deep with emachines as ntfs ive ran windows complete programs on emachines with out a problem and created straight recovery disk simple to be ran in windows safemode
now your hard drive
depending on which brand hard drive you have there is a couple out there that have data compression problems over 80 gig these harddrives over 80 gig have a crash ratio of 8 to 1 sea gate about 2 years ago had this problem dont know if they corrected it yet
quite possible your hard drive did not die at all but the power supply just didnt have the juice to push it check hdd by another source of power
May 12, 2008 | Computers & Internet
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
130 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
