Question about Emerson NR303TT CD Shelf System
Cd player the door to our cd player does not close. when it does, it does not release the cd. The cd door mechanism gets stuck or does not close smoothly or quietly
  • Anonymous Mar 31, 2014
    every time I push the open/close button the cd doors opens and closes and sometimes several times but never stopping to allow me to put cd into it
    Champion:
  • 277 Answers
Hi the gentle macanizem is bad probaply a thooth or a little wheel whats the qustion? you can spry a lubricant spry inside (through the little holes ) NOT ON THE LASER EYE!! it will smooth things out a little bit good luck
Posted on Feb 26, 2006
SOURCE:
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
How can I eject stuck 3 CDs from CD player + GPS 2006 toyota camry grande?
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
Dec 29, 2014 | 2006 Toyota Camry
Why compact disc player model#cafsm3 will not read and play cd/door error
The door close mechanism is linked mechanically to the CD read mechanism .unless the door close signal is relayed satisfactorily ,the CD will not play .get it checked by an authorised person and don't do it yourself since the laser from the lens is harmful .
Jun 23, 2014 | JVC Audio Players & Recorders
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
CD stuck in player after an accident. Got it removed, and tried a CD again and it became stuck. Just had it removed again and now no CD will go into the player. Also, since the accident, the window on...
the cd transport mechanism is plastic when it breaks its f..... you will have to replace it,sorry.as far as the window is concerned,put the key in the door and unlock the car holding the key over will lower all windows,then lock the car and hold over the key,the windows will go up.(that resets the windows and SHOULD reset door rollback.)if not its a computer brain reset.
Aug 25, 2010 | 2005 Volkswagen New Beetle Convertible
It says off and thats all
CD stuck in player.
Unplug.
Remove lid, small black screws on side and along the top of the back.
Fiddle with latch on left side near front that controls the door.
Once latch is released, open door and remove all CD's.
Make sure 2 CD's are not **** in player.
Move CD cage carefully. It should run smoothly along. If not it is locked in 'switched off mode' or CD is stuck half in and half out. If CD stuck fish CD out carefully.
Plug back in without any CD's in.
System should run back and forward and then lock at left hand end.
Put lid on and try one CD in one slot.
Dec 27, 2009 | Technics SL-MC6 CD Player
The open close button does not work. Mechanism seems stuck and I had to pry it open with a screw driver to get a cd out
the door is usually belt driven. unplug the unit and open it look for the belt that controls this function. Your motor could also be bad.
Oct 18, 2009 | Audio Players & Recorders
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Emerson NR303TT CD Shelf System Logo
102 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
