Question about Dryers
Drum bearing - Dryers
  • 550 Answers
Most dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • unpug dryer
  • remove screws from bottom bend of front panel
  • lift front panel off
  • sent front panel aside
pull tensioner pully off bellt
pull belt off motor pulley
pull drum out forward
felts installed on drum edges can be examined for wear, as should roller support bearings
reassemble in reverse order
Different dryers may have: nylon glide plates, felt bearings rubber tired roller bearings or any combination of the above.
Local parts guy will have the parts as they are common to many dryer models.
Posted on Sep 06, 2008
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing support.to repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at searspartsdirect.com, repairclinic.com, apdepot.com, partselect.com, or apwagner.com
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya http://www.youtube.com/user/RepairClinic?v=67hOqSFnX8g&feature=pyv&ad=9033434261&kw=drum%20bearing
Good luck,i hope ya find it very simple to replace that bearing,
GENE
Jan 31, 2012 | Washing Machines
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
How to replace rear wheel bearings
If it has drum brakes, you'll need to take off the center dust cap, remove the cotter pin, remove the nut and washer holding the drum on. The outer bearing should fall out, the inner bearing usually stays in the drum, due to the grease seal. With the front bearing and washer off, put the drum back on and install the nut, then pull the drum, allowing to the nut to catch the inner bearing as you pull off the drum, and that should leave the inner bearing and seal on the spindle. Pack the new bearings with grease, install the inner one in the drum and tap in the grease seal in place, but the drum back on and install the outer bearing on the spindle, the wash, nut, cotter pin and dust cover. Tighten the nut snug and turn the drum a few times and snug up the nut. Don't overtighten it.
Apr 29, 2010 | 1991 Volkswagen Jetta
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Noisy bearing
    1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Drum will not rotate
    im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
    Apr 26, 2007 | Zanussi F1045W Front Load Washer
    Dryers Logo
    144 people viewed this question
    Top Dryers Experts
