My sister has a new acer aspire 5220 laptop, and it was working, but now it will not come on, the ac power light is on but the power button when pressed will not come on.
  • 185 Answers
Check this site it will helps u to solve ur problem
http://www.laptoprepair.co.uk/how-to-repair-laptop-broken-power-socket-connector-pin.htm
Posted on Sep 06, 2008
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
I turn on my acer aspire laptop its power button lights up for 1 second but does't switch on my lappy how can turn on my laptop
first,please tell me,are there any beeps?
or maybe you have already done this, but remember that many laptops require that you remove the battery for about 30sec. as well as disconnect the AC power to reset them. Always try to do this when everything seems completely dead.
Please let me know if it's working or not,and thanks for using fixya
Aug 07, 2012 | Acer Aspire 4820 4820g 4820t 4820tg...
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Laptop acer aspire 5740g. No light indication when i connect ac adapter and no response when i press the power button totaly dead.What is the problem
My laptop been droped.
Dec 16, 2010 | Acer Computers & Internet
My aspire 5520g/5220 laptop just stopped coming on
first check your laptop charger if it ok than check motherboard power supply of laptop..there are must some problem on motherboard.
Apr 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Jun 21, 2009 | Acer Aspire 5520-5579 Notebook
Don't know where to install my new memory on my laptop
Heres a link:http://www.notebooks-drivers.com/acer-notebooks/download-manual-for-acer-aspire-5220.html for the manual of your laptop, memory slots are usually found at the bottom, just download the manual and theres an instructions on how to add or replace your memory on it. good luck
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
