Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 237V Backlight problems
When I turn on my TV the backlight doesn't light completely. It is dimmer than usual and continuously flickers. Does this problem lie in the backlight inverters or the power supply? Or is the problem else where? Any information would be appreciated. Thanks
  • 10,594 Answers
Check inverter supply voltage, (should be constant and stable) if found ok, then inverter or back-light tubes are suspected.
Posted on Sep 06, 2008
47lh90 blinking red light and flickering
the regulator for the Inverter supply would be the first thing i would suspect if the voltage drops then picks up again. Then I would also check the transformers on the Inverter that are in line with the area of the screen that flickers.
Mar 22, 2013 | LG 47LH90 47 in. HDTV LCD
Hello i have a 42 inch samsung model number ln40b550 and i have been having this reaccuring problem where everytime i turn on my television it tends to flicker wildly for about the first 5-10 minutes, it...
This is a common Power Supply / Backlight Inverter Board issue. If you open up your TV you will see a long white board that is on the right side of your TV. You have to replace that board to get this issue fixed. You can find the board here BN44 00264B Samsung Power Supply Backlight Inverter
Jun 25, 2012 | Samsung LN40B550 40 in. LCD TV
Insignia NS-32E570A11 no picture or sound
Just FYI: I had a friend with an Insignia NS-32E570-A11 with a backlight problem, and it turned out to be one of the actual LEDs in the backlight array was burned out, causing some sort of over-voltage condition that made the backlight sometimes work, and sometimes just flicker for a moment at TV startup and then turn off. We took the panel apart and bypassed the one bad LED (it had a dark spot on it and failed continuity - you can test each LED with a continuity tester and see them light up!), and now the TV/backlight works! Be aware this is tricky bypassing the bad LED, as it is ultrasonically welded to the LED array strip (same technique used to make ICs), so you need to be a very good solderer to bypass it without it breaking the connection.
May 31, 2012 | Insignia Ns-32e570a11 32" Led Lcd...
Olevia 237V: Blue panel light glows but TV does not turn on
I am working on the same issue. It is either the power supply or invertor board. Please let me know if you find anything out. did you open the tv and check the power supply for bulging caps?
Feb 12, 2010 | Olevia 237T 37 in. LCD TV
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
Olevia 237V S11 Firmware
for all firmware updates you must go to this site http://www.olevia.com/en-us/Support/Firmware.aspx
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237V S11 Backlight Problems
This sounds like a defective batch of fluorescent backlight sources; have seen this complaint before.
This may be tough to acquire since I don't know how standard those are across the industry and Olevia has filed for bankruptcy so you can't count on them.
Oct 22, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
268 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
