Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Overflowing drip pan under the fridge
Whirlpool Model ET1CHMXKQ03 Refrigerator drip pan under the fridge seems too small. When the fridge self-defrosts, water fills the pan and then pours onto the kitchen floor. Could it be a bad evaporator? Help.
  • 1 more comment
  • Anonymous Sep 06, 2008
    Lots of water is accumulating at the bottom of the inside of the refrigerator under the crisper drawers. Can't figure out where it is coming from. It eventually spills out on to the floor in less than a weeks time.
  • Anonymous Mar 25, 2014
    pan leaking onto floor
  • Anonymous Apr 01, 2014
    I need to find an evaporator pan for a medallion 850 GE fridge,it is missing and the plastic pan just fills up and overflows on the floor. Can you show me a picture where it should be positioned in the back.
    President:
  • 1,462 Answers
For reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
Unit ED5DHEXWQ bought 2 weeks ago Drip pan over flows- water not evaporating quickly. Company tech say I need to modify my frig by placing a heater. 2 The refrig side is not gettinG COLD ENOUGH - MY MILK...
The tech is full of beans. The heat from a normally charged refrigerator is more than enough to evaporate water in drip pan.
The indication of improper charge is that obvious. Fridge warm freezer ok would be a coil blocked with ice, however drip pan overflowing is a charge problem, Ask for a field supervisor.
Dec 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Why is water leaking from the bottom of the fridge towards the back?
If its just a few drips - it's likely condensate from the drip pan overflowing.
Check the door seals. Make sure they are clean and not letting fresh (humid) air in and causing it to be over-worked.
It could also be the freezer defrost pan overflowing from the same issue. Usually there is not enough to fill the fan - as it evaporates with the heat of the condenser.
If there seems to be alot - your water line to the icemaker or water dispenser may have frozen / cracked.
There's really a few reasons that will require further investigation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2010 | Refrigerators
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My fridge is leaking because the drip pan is overflowing
I had this problem and it turns out that the filter cartridge had a leak and a constant drip into the drip pan. The drip pan is designed to capture the runoff from the self defrost but not a constant drip. The first thing you should do is remove your water filter cartridge - this will stop the drip until you can get a new cartridge. If that doesn't work just turn the water supply to the fridge off. You won't have ice but you won't have a leaky fridge either.
Aug 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
1,398 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
