Question about Amana 3.2 cu. ft. Top-Load Washer
Amana top loading washing machine
Why does the washing machine drain when I try to fill it to do a load?
    Problem Solver:
I used another wash cycle. It has worked fine until today, so I can't think it is a hose situation problem. I will probably have to have someone come out and fix it.
Posted on Sep 07, 2008
How to calibrate amana top load washing machine
The fill control valve may have failed (despite the green filling light).
Sep 08, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Water drains out during the wash or rinse cycle
check your drain hose if it is down the drain to far it will **** the water out even while it is filling it sould only be in about 2-3 inches
Jan 23, 2011 | Amana NTW5400TQ Top Load Washer
Wont spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 11, 2010 | Amana NAV2335A Top Load Washer
Water continues to try to fill the machine but just drains out drain remains open
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 01, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Amana top load washer fills with water and will not stop filling
Hi...
You need to check this
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Amana Washing Machines
Water Drains out as fast as it is filling
You have too much of the drain hose inside the drain line causing the water to siphen out as its coming in. Pull some of the drain hose out and secure the hose. There should only be about 8 inches or so of the hose inside the pipe.
Apr 08, 2008 | Amana ALW880WH Top Load Washer
Machine fills and drains
raise your stand pipe up alittle bit lower of the machine
Sep 20, 2007 | Amana DLW330RA Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
108 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
