Question about GE Slim Spacemaker 7-5295 CD Shelf System
ND message The CD player will not recognize any CD's at all.
    Scholar:
  • 48 Answers
It might be an older CD player that can't read computer-made discs, or it could be a disc incapability... If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 27, 2005
My cd is not recognize I get a message that read TOC
If a read head burns out or the alignment has changed, the laser is inoperative. If a CD/DVD was a copy or reproduced on a computer it too may not be read. If the medium works on other devices, then the players laser may be defective.
Mar 01, 2014 | Harman Kardon CDR2 2-Disc CD Recorder
I have an NEC ND-6750A installed in an HP Pavilion ze5570us laptop. I installed it after the original cd drive failed. Windows recognizes the drive but considers it a CD-ROM drive with no DVD...
did you buy this off of eBay? this unit may need to be "flashed" so to speak. the term is firmware upgrade. the HP website has this and i have supplied the link for you. here is thre link for the firmware update:
http://liggydee.cdfreaks.com/disclaimer/en/6750a/261_orig.zip.html
windows should not only recognize it but should reload the drive with the correct parameters.
Feb 21, 2011 | NEC ND-6750A DVD RW Dual Layer Burner
GE Spacemaker, Model 7-5295 the cd light blinks and the cd spins but it does not play. After a short period of time nd flashes.
ND means "No Disc". It's probably a newer CD - one that's been copied, perhaps? It's got a format newer than what the CD player on that unit will recognize. Try an older CD.
Oct 02, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
Nec nd-3540a dont recognize cd's
hi,
1. check your cd is that good are scarbbed one.
2. clean the lense, with lense cleaner
3. try it again cd
4. check your cables for loose contacts
thanks
ehsanullah.
Jun 15, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Cd player keeps showing nd cannot play any type of Cd at all
Hi Tony,
Your GE 7-5295 keeps showing nd (no disc), this simply means that your lens has been damaged. Please replace the lens and you would enjoy listening to music once again in your kitchen.
Kind Regards
May 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
Compaq V2000 - Service Tag V2220US Only recognizes the CD/DVD drive as "CD" Does not see it as a DVD Drive. Listed as: _NEC DVD+-RW ND-6500A in Device Manager.
Try updating your drivers from www.hp.com
If the issue is that it won't play DVD movies only then you probably need to install or re-install the DVD player software that should have come with your computer. If you don't have it anymore, simply download from HP.
Apr 24, 2009 | Computers & Internet
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Aug 11, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6650A DVD RW does not recognize DVD
Refer to http://support.microsoft.com/kb/891894 for solutions to the infamous I/O error. Hope that helps.
Nov 20, 2006 | NEC ND-6650A DVD RW Dual Layer Burner
GE Slim Spacemaker 7-5295 CD Shelf System Logo
187 people viewed this question
Top GE Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Racki123
Level 1 Expert
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
