I have a asdl modem model ZXDSL 531B cant connect two computers at the same time
When i am connected to one computer (xp) and i try to connect my other computers it says the line is  busy how do i connect to both of my computers at the same time one is xp and the  other is vista  i connect both of my laptops using wireless and i think my modem is modem *** router
Generic problem for all Network Terminals I have a asdl modem model ZXDSL 531B cant connect...
Posted on Aug 26, 2009
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
How do i turn off the modem firewall?
If your modem/router is connected via ASDL or Cable then open internet explored.
look below the router/modem and it should have the IP address of the box (ie. http://192.168.1.1 )
Type this into internet explorer.
It should take you to the log on page.
Again read the modem/router though if you cant then try user name ADMIN and password PASSWORD.
This will log you into the modem setup. Click firewall/security and switch it off........Get the model of the modem then type it into google and you will find a more detailed guide of the unit.
Jul 08, 2010 | Arris SURFboard SBG900 (49402201900) Modem
How to connect 2nd computer to internet from bsnl type2 modem modelzxdsl 531b through ethernet cable
Its simple
1. connect a lan cable from ur modem to ethernet switch(For ex: 4-port)
2. Take 2 cables from ur switch ports and connect it to ur Pc's
3. Configure DHCP on your modems. So that ur pc's obtain ip address automatically from ur modem.
This is how u connect multiple computers to internet by a single internet connection
Jul 06, 2010 | Computers & Internet
Hi Everyone! I have a Linksys Model ( BEFW 1154) Wireless model and vonage VT 2142 to be connected ASDL model internet modem with model number (DNA A201BEI). I like to know how to connect the same.
ok then first take a ethernet cable and plug it to the output of the modem and into the input of of router(for the link sys this will be known as the port labeled internet. then use the software for the link-sys and give it a network then wireless connect your computers through that network.
Feb 11, 2010 | Linksys Wireless-G Broadband Router
Broad band connection
we have on type4 modem (zxdsl 531b) how can i connect two pc with this modem
Aug 26, 2009 | Computers & Internet
Want to connect two computer with ADSL C2110 modem to bsnl
use network swich just plug in both computers and the incoming internet
Dec 27, 2008 | Computers & Internet
Modem !!!!
One end of the DSL-modem connects to the telephone jack.
The other end of the DSL-modem connects to the _ETHERNET_ port on your computer -- it does *NOT* connect to the _MODEM_ on your computer.
So, do not look under "MODEMS"; instead, look under "NETWORK ADAPTERS".
Nov 07, 2008 | Microsoft Windows Vista Ultimate Edition
Configuring the usb
First, make sure that the device is working properly on the device manager of your computer. Then, set the wireless settings of the router to the wireless adapter. You can use the wireless utility built in to windows (XP and Vista) or the utility that came with your adapter to fix that.
Normally, the limited or no connectivity may mean that there is a wireless security set on your network and that the network key is set incorrectly. If you are using Vista or XP, try to remove the preferred networks and reconnect once again with the correct key.
Hope this helps
May 12, 2008 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Modem driver
Most of the time the XP drivers for modems also works for Vista. I suggest You try force install of your XP driver. Also check the website for the manufacturer if they released a Vista driver.
Hope it works.
Mar 21, 2008 | Microsoft Windows Vista Ultimate Edition
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
622 people viewed this question
David Payne
David Payne
