Question about Philips TS2744C TV
PLASE HELP ME TO FIND THIS PROBLEM
The TV not turn ON, just a noise coming from the back like Tic, Tic, Tic then the TV woudn't turn on. Thank you
Mine did the same, Ceramic Disk Capacitor C506 was burned out.
If you got a nasty smell of burning plastic, that might be it. At least that's what I got.
Dennis R.
Posted on Apr 17, 2009
Milwaukee 2792-20 M18 Jobsite charger/radio not working
sadly there is no help for things bought from Craigs list try contacting milwaukee thru their website
Aug 29, 2016 | Audio Players & Recorders
TV do not turn on and make a noise as tic tic tic
Main board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2015 | Panasonic VIERA Televison & Video
Philips TV making a strange clicking noise
A model number would be helpful to answer this but:
This clicking sounds (no pun) like either a mechanical relay in the set's power supply or possible arcing somewhere in the set.
These sets also have a shutdown feature that if engaged may sound like a tic-tic sound.
Let me know model number which is not indicated on this question here.
Jun 03, 2012 | Televison & Video
When i start the car, it make a funy noice
i cant tell
is it noise like continuous ticking like tic tic tic tic
or a corrosive sound like chhhhhhhhhhhhhhh
or just engine revving high rpm
is it coming from underneath like muffler or exhaust system ?
describe locate diagnose fix just that simple sir .
Jun 06, 2011 | 1999 Volkswagen Beetle
My rca tv will not turn on, But it makes a tic tic tic inside (no its not a bomb )when i push the on button. It is a ac/dc tv for my van.but my vcr works great when i hook it up to another tv. ...
your tv set has a bad relay short it trying to turn on but the relay then detects a fault and lets go (the tick tick sound) it will need to be looked at by a service tech to have the short found and repaired
please rank this advice if it helped
Feb 13, 2011 | RCA E13345 13" TV
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Feb 23, 2010 | Princeton Digital VL1919 19" Monitor
Ticking noise in the dashboard
it could be ur fan its probly bumbing somthing near it my toyota does the same thing
May 28, 2009 | 2005 Chevrolet Cavalier
TV not coming on
try check the horizontal output or flyback transformer..on the pcb board..sometime lizard die stuck below the pcb and tv shock when you switch it on
Dec 08, 2008 | Samsung DLP HL-P5663W 56" TV
Tv cliking wont power up
The tic tic sound is a device called safety switch that keeps turning your TV off because an internal fault, such as a defective component or a wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hard reset), this will drain power from tv and seset internal circuit, and sometimes can clear the error message, if the fault was only temporary.
If the problem does not go, probably some component inside the tv is faulty and may need to be replaced.
If the tv is one month old, it should be covered by warranty, call the phone number listed on the TV owner manual.
Sep 19, 2008 | Televison & Video
Tappet like noise
maybe your timing belt is shredding and hitting the plastic cover.
Jul 11, 2008 | 2002 Daewoo Nubira
Televison & Video Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
