Cars & Trucks Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I had a start problem with my celica. tried to turn the car over and a constant clicking sound was made, however all lights were on and the radio was working.. thought possible starter problem, however, I have tried it again this morning and the alarm seems to be constantly engaged even when I have unlocked it!!! The alarm keeps going off.. Maybe this could be the problem? If so is there anyway of reseting the system and how?
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on Aug 17, 2011
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2960136
Points
18833
The problem is that your battery is extremely low. The repeated clicking sound is your starter relay trying to engage, then releasing again when the starter takes the remaining voltage available to try to turn. When the relay disengages, the starter can no longer take any voltage at all, so the relay again engages and the process starts over. This results in "CLICK, CLICK, CLICK, CLICK...." There simply is not enough power available to operate both the relay and the starter.
Your alarm system doesn't have enough voltage to function properly. It "thinks" that someone is trying to steal your car or is messing with your battery cables. It doesn't know the difference between low voltage from a dead battery and low voltage from somebody disconnecting wires. It is simply responding to the low voltage condition as it is designed to do. Fix the voltage problem and you will fix your security system. No need to reset anything.
Jump-start the car or replace the battery and get your charging system checked to make sure everything is functioning properly. It is possible that the battery is good but you have a bad alternator and the battery is low because it is not being charged.
Randy Ohler
Level 3:
  • Toyota Master 14,585 Answers
Randy Ohler
Toyota Master
Level 3:
Answers
14585
Questions
8
Helped
3939666
Points
39683
Sounds like the battery to me. Constant clicking is a low battery. And when it gets low enough this will make everything else go crazy. Like the security.
2answers
I was driving my 97 Celica 2.2, cruise control on at 70 mph. It just dies. No sounds.. Just shut off. Now won't turn over. Its auto it I would've tried to push start it. I'm thinking a ground cane loose...
Check your ground connections from the battery to the frame and from the battery to the engine block of your celica check all fuses and relays if nothing else check battery cables themselves for tightness and any corrosion
If you need further help, I’m available over the phone at https://www.6ya.com/expert/james_7e1192bbb9f949fa
1helpful
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
When i try to start my car all i get is a constant clicking sound, the radio and lights come on.
Its possible that you dont have enought charge to start, but yes for turn on radio and lights; check charge battery and after, check the starter, its possible that go to bad.
Keep us updated.
3helpful
2answers
1998 Celica engine won't start, rapid clicking audible
sounds like you are on the right track, the battery you have in it has done well to last that long but it sounds like a fell cells have decided to call it quits
Toyota celica 2.0 gt 1994
sounds like a dirty fuel fiter. Start with cheapest fixes first. if not that maybe fuel pump is going bad.?
Fuel pump no kicking in
Click on link & scroll down to figure 5 & 6 . Click on picture for expanded view.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528007cb56
1999 Celica, wont start, just "clicks".
if it's clicking, it's probably the starter. most auto stores will be able to test it, but you have to take it out yourself.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
