posted by robert on Dec 26, 2005
when I connect my VCR using the video input jacks and use the conpent video jacks for output to my TV I get a very jittery picture. It's like the upconversion can not handle the VCR input.
1 Other User Has The Same Problem
Comment by TY85, posted on Dec 04, 2007
Have combination VCR/DVD, When playing VCR thru RX-V557, picture is unstable as if not properly sync. VCR connected direct to TV works properly. Have tried several VCRs with same result.
Best Solution
posted on Apr 01, 2006
check the wires, they could be bad. Or maybe your vcr head needs to be cleaned
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 11, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
You might need to run a composite video cable from the receiver to the TV. The operating instructions say that if you hook up a video source using the standard video connections, then you need to hook up your TV using the same video connections. You should only be outputting via component video to your TV if you have video sources hooked up via component cables. This may be the problem...I don't think the HTR-5830 upconverts from regular video to component.
Suggest a new solution for this problem
Post a New problem for Yamaha HTR-5860 7.1 Channels Receiver
Email this problem
Email this problem
This Problem Also Relates To:
Kenwood 1080VR Receiver
Kenwood KR-X1000
NAD C425 Am Tuner Tuner
Sony STR-DB790 6.1 Channels Receiver
NAD 712
Philips FR965DHT 5.1 Channels Receiver
Philips FR975 5.1 Channels Receiver
Can you Help with these Receivers problems?
Repair Service
Find Receiver Repairman Near You:
