Question about Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop
Both of my CD/DVD Drives in my computer are not working correctly. My computer recognises them but when i go into my computer only my floppy drive comes up under devices. when i went into device manager, a small yellow caution sign is displayed and the message displayed is 'This device cannot start. (Code 10)'. whenever i disable and enable or uninstall and reinstall the drive the same thing happens. because of this i can't listen to music, play dvds or install the new printer i have purchased. On top of all that my computer will not shut down at all. whenever i press shutdown the screen appears with the words 'Shutting Down...' and remains like that for hours. Please help!
  • 54 Answers
Try to Reinstall you OS this may solve the both problems
Posted on Sep 06, 2008
Boot disk not recognisable
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Mar 04, 2012 | HEWLETT-PACKARD Hewlett Packard 465899-003...
"CANNOT START,CORRECT HARD DISC NOT
make sure there are no disks in floppy cd usb drives
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
hope this helps
Jun 12, 2011 | Computers & Internet
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Andrew.A
Apr 07, 2011 | Maxtor Hard Drive
PC no longer recognising device
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 10, 2010 | Maxtor Hard Drive
The drive does not appear on My Computer, thus I can't access the files. The computer does recognise it on Computer Management, and the latest driver is installed. In Device Properties under the General...
hope this helps
Oct 02, 2010 | Western Digital Caviar SE WD2500JD 250 GB...
Computer does not recognise CD's, DVD's and floppys
try on stetting master and slave jumpers on back of cd,dvd,and about your floopy don't know what could be....
Apr 09, 2010 | Computers & Internet
4600c not operating system error message bootmanager missing
You might have to go to the BIOS of your computer to ensure your drive is recognised. Once it shows there, make sure you change the Drive as your first boot device.
Thanks
Ranjit www.supportminds.com
Aug 14, 2009 | Dell Computers & Internet
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
IDE Drive not found on startup
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Nov 13, 2008 | Dell Dimension E310 PC Desktop
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
