Question about Kenmore 24032\24036 Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
Somehow a cotton t-shirt is wound around the spinner thing. I can't pull it out (I can get pieces but then the rest of it might get stuck under). Can I lift off the cneter spin thing and pull out the fabric? thanks!!!
Tracy
  • Anonymous Jan 29, 2009
    i have removed the bolt but cannot lift the agitator out.
  • 958 Answers
Yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Posted on Sep 06, 2008
I have a kenmore 800 series washer that makes a loud slamming noise at the end of the spin cycle. If you lift the lid during the spin cycle the basket slams to a halt immediately. It actually moves the...
Those parts you can check
1/ strings holding the drum were broken causing drum unbalancing when it spins.
2/ Drum bearing also gone. (noise)
3/ 3 slides that located underneath the triangle frame need replaced.
Oct 22, 2013 | Washing Machines
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Shirt caught under agitator how do I get agitator out to unwind shirt
you need to pry the softener dispenser cup off the top of the agitator,then you need a 7/16"socket with an extension to remove the nut located down inside there,then lift the agitator straight upward
Mar 23, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Removing the Agitator on a G157 Hotpoint washing machine
Some models have a bolt towards the bottom of the outside of the agitator, depending on model. If it has one, take out out and you'll have to yank on it VERY hard to get of off (you'll most likely lift the machine off of the ground a few times in the process!)
If the bolt isn't there, its under the top cap of the agitator "somewhere". You'll still have to yank up on the silly thing to get it off after taking the bolt out.
Jan 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
364 people viewed this question
Sal De
fordexpert
Robert Rankin
