The washing machine drains when you try to fill it
    President:
  • 1,462 Answers
If drain is into a standpipe then you have the drain hose pushed too far down the standpipe - only needs to go in a few inches. if drained another way, take the drain hose up in a swan neck to about worktop level.
i suspect the water is syphoning out
Posted on Sep 07, 2008
My wash machine tries to fill, but it sounds like the pump is pumping it out as fast as it fills.
The number one suspect reason for simultaneous fill and drain would be that your washing machine drain hose is inserted into your wall drain too far. The drain stack pipe in the home should be as high on the wall as the top of the washing machine main top/lid, and the hose from the washer inserted no deeper than 10" and properly secured to one of the adjacent water shut offs with a zip tie. If this is your issue, your drain system in the home is creating a siphon through the washer drain hose and literally sucking the water out of the washer. Pleazer Appliance...
Apr 15, 2014 | Admiral Washing Machines
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Does not fill to wash
If draining is occurring at the same time as it is filling you have siphoning happening. There could be 2 reasons for this.
#1 the drain hose must be higher than the washer tub before it connects to the drain pipe in the house.
#2 the drain hose from the machine must not stick into the house drain more than 6" - if it is pushed down the drain too far it will siphon out the water in the machine.
Apr 21, 2010 | Whirlpool LSQ8000 Top Load Washer
Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
Apr 16, 2010 | Miele Novotronic W1918A Front Load Washer
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
Dec 27, 2009 | Washing Machines
Trying to drain and fill at same time wont switch off
pull the drain hose up out off the stand pipe until only a few inches of hose are into the drain. you are siphoning. happens all the time
May 25, 2009 | GE WBSR3140DW Top Load Washer
Wash machine is draining while trying to fill up
Make sure your drain hose only goes into the stand pipe about 4" and secure it. If it goes in too deep a siphon will occur. Also make sure your stand pipe is not too short. It needs to be 18" above the trap or 30" above the floor. If it's less, then siphoning can also occur.
May 19, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
