Question about Cameras
I have a cannon powershot A530 camera. It wont turn on even although I have changed batteries. The lens is still projected. the batteries are in the right positioon and iI have now installed new rechargeable battries which are fully charged.
  • 1 more comment
  • lynxrun Sep 08, 2008
    The camera was not dropped to my knowledgr It is two years old
    I would like another opinion.
  • lynxrun Sep 11, 2008
    I dont mind taking it to a repair shop but i would like to get a definition of the problem.
    President:
  • 1,263 Answers
Chances are there is either a disconnected wire form the battery contacts or you have a chip that has gone bad. if you feel comfortable opening the case look to see if the wires around the contact are still attached(they should be soldered) if they still are this means that you have a bad circuit on the board. there is no repairing this it is far cheaper to replace the board than it is to have a tech repair it.. if the price of the camera is more than the cost of repair than it's worth having a tech take care of it,however if it is the opposite just purchase a new one. please rate this...thanks
Posted on Sep 08, 2008
    Scholar:
  • 141 Answers
Since the lens is projected, this would indicate that the camera failed while it was ON.
The camera is faulty and in need of repair.
    Master:
  • 763 Answers
In that case and still no progress about the problem, better send it to repair service for fixing some hardware of your camera. thats the best you can do. i hope that your unit is till cover on warranty service so that you dont have to pay for fixing your unit. hope that helps!
CHARCOIS
    Genius:
  • 2,035 Answers
Remove battery / batteries from camera and with a pencil eraser and/or a clean soft cloth rub the metal contacts of the batteries as well as the battery terminals in the camera. Reinstall battery / batteries and power the camera on.If above troubleshooting steps have failed, then the issue you describe seems to indicate that your product requires repair service. IF camera is under warranty then you give to the company, or you use these links
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
Good luck..
Posted on Sep 06, 2008
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
Did the camera has dropped? how old now the unit..
  • 13,433 Answers
Hey,
Try pressing the reset button / hole its either near the connections or the battery hatch.
Do you have warranty? try pluging the camera to your pc, does anything happen, you may have to send this in for repairs.
  • 2 more comments
  • Ekse Sep 06, 2008
    if you are out of warranty I can recommend
    -free repair estimate
  • Ekse Sep 06, 2008
    how old is this camera?
  • Ekse Sep 08, 2008
    UNable to see my solution?
  • Ekse Sep 08, 2008
    my solution been here for 2 days and you haven't seen it at all?
How do i turn off the flash on the cannon power shot a530
Press cursor-up on the round cursor pad (marked with a lightning bolt) to change the flash modes. To turn the flash off, select the lightning bolt in a circle with a slash through it.
May 15, 2010 | Canon PowerShot A530 Digital Camera
When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
I Have A Cannon Camera. And It Wont Turn Back On!
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 17, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a cannon powershot a 85 it was working fine then nothing i turn it on and it lights up the cannon sign then goes of. it is showing E18 in bottom legt hand corner. i have tried both rechargable and...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
My canon A530 will not turn on
Damaged Lens Block.
Needs to be replaced.
Mar 20, 2009 | Canon PowerShot A530 Digital Camera
My canon powershot A530 WONT TURN ON!!!!
Check the batteries, and if they are bad, replace them. If it has rechargable batteries, just get rid of them and try regular alkaline batteries. That should be the fix.
Oct 05, 2008 | Canon PowerShot A530 Digital Camera
Green Light Turns on, Sound of turning on, lens comes out, but then goes back in a turns off. . .It's not the batteries. PLEASE HELP ME!
Note that some batteries just don't hack it in digital cameras, even if new. This is especially true for those "super heavy duty" batteries:
http://camerarepair.blogspot.com/2008/02/simple-fix-for-digital-cameras.html
OK, so it's definitely not the batteries. A few of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
May 24, 2008 | Canon PowerShot A540 Digital Camera
Camera turns off after lens comes out in shooting mode.
I'd recommend that you stop banging or fiddling with the lens as it does not sound like a lens error (if it were so, you'd still get an error even in review mode). Instead it sounds like the brand of batteries that you're using may not be providing sufficient power.
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Most retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
May 15, 2008 | Canon PowerShot A530 Digital Camera
Short battery life
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
Dec 31, 2007 | Canon PowerShot A530 Digital Camera
Powershot a540 "cannon"
Dec 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
