Question about Panasonic DVD-LX9 Portable DVD Player
Error Message H02
The DVD doesn't load, then the message Error H02 is displayed. Took the unit to Best Buy to send to Panasonic for repair; however, they said Panasonic would advise to just buy a new one - repairing is as expensive as a new purchase.
I have had this problem on numerous times. Once while in warranty. Discussed with technician and he reported that the gears get dirty and stick and need cleaning. Since last year, I get this message every 3-4 months. I take out all the screws from the bottom, open the cast carefully, and use some canned air, clear all the gears, gently rotate all of them. Put everything back together and should work fine.
Posted on Sep 28, 2006
I had the same problem "error code H02" with my panasonic dvd player LX8 for 8 months. I did everythig but nothing helped.
Finally I solve it with the help of an electric hair dryer in it's cold air fan position. Every time the same error code H02 appears the hair dryer solve it by strong cold air flow around the optical system as well as the weel. No need to unscrew the device just open the door and let the air flow do his best from different angles.
hope it will do for you too.
yours,
Shaya.
my e-mail is shaya.shakeri@gmail.com
Posted on Feb 04, 2009
    Novelist:
    Champion:
  • 277 Answers
My Panasonic CV51 player (the one with the 5 disk changer) died after 14 months with error H02. No amount of power cycling or trying different CDs worked. All Panasonic would do was tell me where a repair center was. I fixed it as follows (at least, it hasn't failed again since I did this.) If you don't have the disk changer model, the procedure is a bit easier than this, since that technique was posted elsewhere by Jason for a Panasonic model 31. Standard disclaimers apply!! Don't try this if your player is still under warranty. Don't electrocute yourself. Don't blame me if you break anything (but if it was working, why would you waste your time doing this?) I assume no responsibility, etc., etc. Unplug power cord. Remove 2 large screws from each side of case. Remove 2 screws from back of case (near the top). Lift off the cover. Plug in power cord. Turn on power. Press the open drawer button. When the drawer is open, unplug the power cord. On the left side of the unit, see where the actual DVD player is, beneath the platter? Reach in very carefully (it helps if you have skinny fingers), and turn the large white plastic gear and the cone-shaped black CD wheel manually, back and forth a bit. Reverse steps to reassemble. Something must have gotten stuck. My player works now. I can't promise anyone else's will. Thanks to Kimi for the suggestion. I'm just passing it on, since it helped me.
Posted on Dec 27, 2005
I tried the solution provided on my DVD-CP72 model (5 - disc) and it did not work. However, with the cover still off, I put in a DVD. When the player 'picked it up' to play I gently spun it and the player started working again. I put it back to together and it is working right now. Will see how long it lasts.
Posted on Dec 02, 2006
  • Brett Bottcher Dec 06, 2006
    It did not last a week. Probably will just buy a new one. They are really cheap now.
  • 4 Answers
This is what I did and it worked
Power up unit
Eject dvd
While try is open, remove the tray faceplate by pulling up on the faceplate while holding the tray. Be carefull.
Close tray without a DVD in the tray
Remove power
Remove four screws on each side and three on back, then remove cover.
Remove faceplate by releasing three tabs on bottom and two on side.
Remove the tray unit by removing the four brass colored screws (use a magnetic screwdriver helps)
Remove ribbon cable and small, two wire connector on board
Turn tray assembly upside down
You'll see two silver things the size of a pencil eraser. These are the endcaps of the motor. You want to locate the one that is more toward the center of the assembly (the off-center one is the motor for the head).
If you are lucky like me and have a relative that is a diabetic, get a hyperdermic neadle from them, fill it with a light oil (like RemOil) and stick it in the hole that is off-center of the spindle motor case end. The hole is about the size of a toothpick.
You can test to see if this works by putting the assembly back in, reattach the ribbon cable and other cable, and attach the faceplate. Try it out. It took a few oilings before it worked for me. Then assemble everything in reverse order and you are set. GOOD LUCK!
Posted on Aug 28, 2009
My Panasonic DVD-RP62 stopped working and gave me the HO2 message. Following the advice on this site, I took the cover off, plugged it back in and opened the DVD drawer and unplugged it again.. I got a can of silicone lubricant and (using the little tube that comes on a can of WD-40) sprayed a little on the motor shaft of the motor that spins the DVD. Now it's working again. This is a great website and has saved me the cost of a repair/new DVD player. THANKS
Posted on Aug 27, 2009
I had a H02 error message and tried back skip/play/pause with no luck tried shaking but in the end i just inserted a finger behind the optical eye and moved the whole metal platform,something must of been sticking.
Posted on Oct 19, 2007
Hi this was great. had dvd player sitting around for one year oversomething so simply. it does work.now we know what panasonic is all about.purchase purchase!!!!!!!!!!Thank you again.
Posted on Feb 15, 2007
Thanks.i am just passing ERROR HO2. i place my DVD-RV31 above my RECEIVER. is ERROR HO2 problem becaus the top of RECEIVER is too hot??
Posted on Jan 14, 2007
The motor is burned out and you're screwed. The DVD will spin, but not high enough RPMS for the laser to read. I even tried lubeing up the spindle, didn't work. Next time, don't leave the DVD player on for days at a time on Pause.
Posted on Oct 07, 2006
This did not work for me but it was a big help
Posted on Jan 09, 2007
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Dec 01, 2009 | Panasonic Televison & Video
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
H02
This weekend we were watching a movie. It started to skip. I thought it was a dirty disk, took it out, cleaned it with a dry cloth and put it back. Now nothing will play.
When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message H02 and the manual says to call for an explanation.
We tried turning the machine off and on and we tried pulling the plug -- no luck. What is the problem?? Jeff
Apr 06, 2008 | Panasonic DVD-RP56 DVD Player
H02 Error Message
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Apr 02, 2008 | Panasonic AG-1980 S-VHS VCR
Discs cant be played..
More information:
Your DVD HO2 error problem appears to be Panasonic specific: Go to this link:
http://www.hardwareanalysis.com/content/topic/55214/
Feb 11, 2008 | Panasonic SC-HT880 System
Error message when playing any DVD in Hi-fi
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Feb 28, 2007 | Technics SCHD560 CD Shelf System
Panasonic DVD-LX9 Portable DVD Player Logo
5,151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
