Question about Compaq Evo N1020V Notebook
Monitor Sound I have a Compaq W17q monitor and don't know how to activate the sound. Can you help me?
My W17q monitor suddenly stops working
go into control panel , display setings and adjust display to never turn off
Feb 05, 2013 | HP Compaq W17q Monitor
Can I connect a DVI to a Compaq W17q
No - it uses VGA 15-pin D-type connector according to the specs.
Feb 03, 2013 | HP Compaq W17q Monitor
The guide you told me to use did not have my model number W17q so I could not use any of the information.
Hello, try this link to the hp website where you will be able to view a user guide.
http://h10032.www1.hp.com/ctg/Manual/c00881436.pdf
If you want further info, then go to the main hp website:
www.hp.com
and select 'Support and Drivers' then on the next page, type in your
product 'W17Q' press 'search' then on the next screen scroll down and you'll see several options from which you can choose.
Regards,
nicam49
Jan 16, 2012 | HP Compaq W17q Monitor
My compaq w17q won't turn on. Help?
check if your compaq w17q power cable is properly connected to the AC adopter if not the change the power cable.
Mar 08, 2010 | HP Compaq W17q Monitor
I have a compaq w17q monitor and the osd locked message keeps popping up. how do I get this to stop?
Hold the menu button in WHILE turning on the power. This toggles the state of teh OSD lock.
Nov 04, 2009 | Philips 150S4FB 15" LCD Monitor
No sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate
May 02, 2009 | HP Compaq W17q Monitor
Compaq w17q monitor keeps going on and off how can i fix it?
1. check the power cords- make sure all are snug.
2. check and make sure no pins are bent in the cord to the computer
3. make sure that the monitor is not in auto-power save. Or in auto off mode. For example- is the light amber or green.
4. finally, make sure that your settings on your computer are not set to power off your monitor- as in a blank screen saver, power save or hibernate
Mar 26, 2009 | HP Compaq W17q Monitor
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
Computers & Internet Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
