Question about Sony Ericsson Walkman W810i Cellular Phone
Camera button not working
Hi there
The button that you press for the camera has stopped working. It might work every now and then after a lot of pressing. I have taken the back cover off and cleaned it but it still wont work.
  • 94 Answers
Andyirwin80 hello,
By default, the camera button in the W810i isn't the most successful one.
It usually requires a stronger press inside, until Camera Mode is on.
I'd suggest sending the handset to a certified lab if it is still under warranty.
If not, take the back cover off after having turned your phone off. Remove the battery.
Unscrew the little screws at each side, and divide the two panels.
On the panel with the camera button, please make sure the button is located above the pad that should be pressed and that there are no interruptions.
Then, put everything back on, and check if the button works properly.
Posted on Oct 29, 2008
Our Text button has suddenly stopped working any suggestions
to be sure you could check if it is the button (remote controller) or the tv. use a digital camera. not the camera of your phone. my iphone 5 filters the ir out.
hold the remote for your camera and press a button you know still works. you should see a bleu light flashing in in the front of the remote. if so, press the text button and see if the light works or not. if it does not, your remote is defect. as a tech, i sometimes manage to clean up a remote and sometimes it then works for a few months. but if it is a button you often use i think you even can't do any good.
most buttons are on a rubber mat, and the other side is just conducting. if a drink came over the remote, opening it and cleaning out the sticky stuff could help. dot if you dont have technical skills and no knowledge of electronics, leave it and just buy a new one. will save you a lot of frustration.
Jan 21, 2015 | Samsung Televison & Video
Scroll problem
Press power button for 10 seconds for camera to shut down. Remove battery. Pres power button. Put the battery back in. Press power button again.
When after powering on, please check if there are firmware updates and update camera, preferably by physically connecting it to a computer.
Aug 22, 2014 | Samsung WB150F Smart Wi-Fi Digital Camera...
Flash stopped working
The flash in the Camera can be enabled to Flash Forced ON by pressing the Up Arrow control button on the Camera. Press the button continuously to select the desired settings.
Make sure that the Camera Mode (REC MODE) is not set to Burst or Multi Burst.
Flash will not work when the Camera is set to ISO High Sensitivity mode or Twilight mode in the Scene Selection.
The flash will not work in Movie Mode also.
When using the Landscape, snow or Beach mode, set the Scene Selection to Flash Forced On.
This should resolve the issue.
Thanks for using FixYa.
We wish you a Happy Holiday Season!!
Dec 26, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
The camera on my tocco lite has stopped working
http://www.knowyourmobile.com/samsung/samsungtoccof480/samsungtoccof480reviews/97080/samsung_tocco_f480_technical_specifications.html
Feb 13, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
IPhone camera stopped working
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
Sep 15, 2009 | Apple iPhone Smartphone
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Button mixup problem?? HELP PLZ!!
it requires a switch block assembly. this part includes the keyboard for play, rewind etc.. part # is 1-477-084-31 part should run you about 30 bucks. Larry
Sep 18, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
May 07, 2007 | Canon ZR300 Mini DV Digital Camcorder
Sony Ericsson Walkman W810i Cellular Phone Logo
305 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
