Question about Coby CSP-94 Speaker
Do not know what to hook subwoofer to - TV, DVR?
And what cable to use and where to plug it. we got 1 fairly long cable with three plugs on each end and 3 short 6" cables with 3 outies on one end and 1 plug on the other.
  • Coby Master
  • 5,568 Answers
This should all be described (at least in Chinglish) in a user guide.
For sure, two of the threesome cable are right (red) channel and left (white) channel. The remaining one probably for center or rear.  Mostly all of the different pieces should have color-coded in- and output jacks.
Look at the connector legends printed on your devices, they should have markings such as "line" both in- & out- and you will find corresponding markings on each.
You would need the 'out' connections from either the DVD and TV to end up on the 'in' connectors of the Coby main unit, presumably the woofer cabinet since these mostly house the electronics; i.e. power supply and amplifier.
Posted on Sep 06, 2008
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
Feb 06, 2011 | Computers & Internet
How do you connect the cable to the tv? I have a dvr box but dont know where the connection on the tv is?
Cable from box to t.v , from antenna to box . If you have a hdmi cable plug into the back of the box, and plug into the hdmi input on the back or side of your t.v
Jan 17, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
Got new dvr box (not HD connection). had to use inputs that xbox was connected to on tv for my dvr. how do I connect the xbox 360 now so that we can use it without switching out the connections?
There are a couple ways to do this. The cheaper way is to buy some RCA Y adapters. You'll need one for each input (3, probably). Plug the male end into your TV, then plug the (yellow, red or white) cable from the XBox and DVR into the other ends of the cable. The downside of this is that you'll need to turn off the box you're not using in order to see the screen OK.
The slightly more expensive way is to purchase a switch box from Best Buy or Radio Shack or any where on the internet. The switch box will work like the Y adapters, but you can have both boxes on. If these are the only two devices that you need to use, then you only need a 2 way switch. Buy the switch and three RCA cables. Plug the RCA cables into the back of the switch in the output holes, and plug the other end into the TV. Plug the DVR and XBox cables into the input sections of the switch. Then you press one button for DVR on the switch and the other button for the XBox.
Oct 02, 2010 | Microsoft Xbox 360 Elite Console - Black
Connecting my new DVR
i dont know what kind of dvr you have, but mine has component terminals to plug my cable box in, and out plugs that go to the tv.
Dec 31, 2009 | Audio Players & Recorders
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
Sony DSC-W170
Your Sony Cyber-Shot DSC-W170 came with a cord that had a little flat plug on one end and three separate plugs on the other end.  The single plug goes into the bottom of your camera.  The end that has three plugs has
(1) USB
(2) video output
(3) audio output
(2 and 3 are for hooking up to your TV)
If you connect the USB end to your PC and the single, flat plug into your camera, this acts as the USB cable.  There is no USB plug on the camera (for just a USB cord).
Feb 23, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Apr 03, 2008 | Yamaha YST-SW160 Subwoofer
Coby CSP-94 Speaker Logo
405 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
