Question about Sharp Microwave Ovens
Need instructions for Sharp Carousel Micro. Label with web site also says TLAB-A183
  • William Miller
    William Miller May 11, 2010
    Sharp model numbers normally start with "R".
    Can you check again?
    We'd be happy to help.
5 Suggested Answers
informatica
  • 1113 Answers
SOURCE: I need Aan instruction manual
Hi - You can download the manual from the link underlined in blue below:
R-305KS
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 07, 2008
fieldy14
  • 456 Answers
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
Posted on Aug 16, 2009
SOURCE: I NEED A MANUAL FOR
I was looking for a manual for the oven, finally found someone to talk to from Sharp Co.
He did not have a manual but had me try some of the buttons on the front of the oven.
Some, in fact most, of them do not work. It was the convection part of the oven that I wanted to use because I am alone and do not always want to heat the oven for just one small something.
I am afraid it has been stored too long and would cost more to have it fixed.
Thanks for the e-mail.
Jane Josselyn
Posted on Aug 01, 2008
  • 4090 Answers
SOURCE: can i bake cookies on my sharp carousel with bake
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Posted on Oct 11, 2009
SOURCE: How do I get our Sharp Carousel R-1611 off the
You need to remove the hood (the grille cover above the microwave door and above the control panel) by lifting up on the bottom of the hood (the plastic should flex pretty easily) and popping it off. On the far left and right you should see two phillips screws, most likely bronze colored. You need to remove them (they are quite long) completely. The microwave will still be sitting on its support arms (which enter the chasis of the microwave from the rear). Once the screws are removed you need to lift the microwave up and pull forward - it should come off of the supports, but you might have to jiggle it a bit.
Don't forget to unplug the microwave and disconnect any ducting before lifting it off of its supports.
Posted on Nov 12, 2009
I have lost my operating manual for my sharp carousel sensor microwave oven model R 480B K
Have you tried the manufacturers web site to see if you can download the manual.
May 23, 2016 | Sharp Microwave Ovens
How many watts has my R-9H83 Sharp micro/conv.?
No idea, but the label on the unit should tell you.
Aug 15, 2014 | Sharp Carousel R530EST Microwave Oven
NEED MANUAL4 SHARP CAROUSEL MODELR403KK SERIAL 173160
You can download the owner's manual from my site here at no charge.
May 31, 2012 | Sharp Microwave Ovens
No instruction book for Sharp Carousel Micro-Conv Model R-7A85 Serial # 40483
You can find many of them online here.
Otherwise, you would have to order yours.
You can order Sharp parts and manuals from Encompass here or you can call them toll-free at 866-779-5835.
Oct 09, 2011 | Sharp R-7A85 Microwave Oven
I have just purchased a second hand Sharp Carousel Convection Oven, but there is no manual. Can someone help where I can download one from
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, and Installation Instructions as required.
I hope this helps.
Jan 16, 2011 | Microwave Ovens
When I shut my microwave door, the light staays on and the carousel starts going around. I can program my cooking time but, it will not engage and star cooking. Meanwhile, the carousel continues to go...
It's probably a bad door switch or door switch mount, probably the top one, which is the door sensing switch.
We have the actual service manual for this model and have uploaded it to our site for you here.
You can order Sharp parts from
Encompass here or from the Sears Parts Direct Web site.
Jan 15, 2011 | Sharp R930AW Microwave Oven
Need to know the cu. footage of the Sharp Carousel Microwave/Convection Oven, circa 1984 or so.
Contact the Sharp web site with your model number for information on your Microwave. They hold a PDF of most models going back many years.
Hope this helps.
Nov 07, 2010 | Microwave Ovens
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
Aug 16, 2009 | Microwave Ovens
Sharp Carousel R 9H56 Instruction manual & Cookbook
http://www.sharpusa.com/products/TypeDownloads/0,1087,5,00.html
Here is a link for your model.
Feb 23, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
687 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
