When i switch on my Epson stylus 880 printers all the lights flas at the same time, the green on light,the paper light & the ink light
  • shazmaz Sep 07, 2008
    hi the problem happened when i was replacing the black ink, I have tried to replace both lots of inks again & all lights are still flashing any idea anybody beforw i go out and buy a new printer!
  • 535 Answers
U have to chak your cardgie ink is it empty thats y this error come
Posted on Sep 06, 2008
When i turn on the printer all the lights are blinking, i have reset the printer many times, restarted my computer and nothing has worked to help the problem. I just printed yesterday with this printer...
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Feb 17, 2011 | Epson Stylus 880 InkJet Color Printer
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Red light keeps coming on and green one keeps flashing
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
May 20, 2010 | Epson Stylus C62 InkJet Printer
Printer Epson Stylus 880 quited - all lights flashing.
I finally solved this problem by simply unistalling printer from computer and reinstalling it without a disk by means of the Control Panel “Install hardware” . Henry
Jan 26, 2009 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Color 880 printer problem
from Kradinsky "Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Dec 17, 2008 | Epson Stylus 880 InkJet Color Printer
Light Flashing
print a test page and allign the cartridges from printer maintenance....
Aug 10, 2008 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Photo R220 InkJet Problem
this sounds like ur both cartridges are empty...
Jul 28, 2008 | Epson Stylus 880 InkJet Color Printer
Epson won't print and all lights flash
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
57 people viewed this question
k24674
jasbo
jasbo
