Question about Microsoft Windows XP Professional
SOUND CARD /MULTIMEDIA CARD
AFTER RE-FORMATTING MY PC, THE SOUND ICONS ARE DISAPPEARED.WHILE PLYING CD/DVD EXTERNAL SPEAKER CANNOT PLAY ANY SOUND. I AM A LAY MAN. PC SAID SOUND CARD NOT FOUND. WHAT I WILL DO ? I EVEN DIDN'T KNOW WHAT WAS THE PREVIOUS AUDIO/VEDIO/MULTIMEDIA CARD/DRIVER.
C.PLAYER, INDIA
  • 535 Answers
Remove from the mother bord slot & reinsrt it & install the driver of a sound card
Posted on Sep 06, 2008
Can't get sound when playing cd r dvd
If the CD-R/DVD has sound in another computer or player be sure your computer's external speakers are powered and on. Quit the player application that you are using for the DVD. If you are using the computer's internal speakers, or if the external speakers are plugged in and turned on, go to the System Preferences and open the Sound control panel. Be sure that the correct output sources is selected. Open the CD-R/DVD player and see if the sound now works.
Jan 28, 2014 | Computers & Internet
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
How to add External Speakers to HP Omni 120?
If your speaker icon is missing go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or 5.1.
There is only one small green 3.5mm speaker output in the back. Number 5. That's it!
Anything else is on the Microlab side. They should chain togetherending up with that small male 3.5mm plug. GL11_15_2012_10_35_24_pm.jpg
Nov 13, 2012 | HP Omni 120-1125 20" All-in-One Desktop PC
All everything i play dont have sounds.like music,video
what laptop model do u need drivers? if not. download VLC from filehippo.com it will play all media music and everythign
Mar 23, 2011 | Computers & Internet
I have copied camcorder film onto a cd but it will not play on my dvd player/TV
There is a difference between copying and recording. If CD is used, probably the format is not DVD format. Only few players accept Video CD and other similar formats. If a DVD is recorded, then it must be finalized in the recorder itself for plying back in other units.
Nov 13, 2009 | Televison & Video
Sound is coming when we play songs
make sure the connections are right and no loose connections,, and pc is earthed
Sep 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
I can't hear voices when i play a dvd on my computer, just background sounds. i've tried many different dvd players (windows media, apple, etc) and have also checked my settings for mono or stereo speakers...
You should also check your DVD playback software and make sure that you have it set for desktop/laptop speakers and NOT for something like 5.1 or 7.1 surround etc.
Jan 03, 2009 | Computers & Internet
Sound echo when plying DVD
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
31
Aug 25, 2008 | Computers & Internet
Sound not coming out of speakers
just remove the cord from CPu...the sound cord and re-plug it and try the option line out or line in...
otherwise simple way is that...check wheter there is sound installed in Control panel under the add or remove program tab....
if not,then install the driver from *********** Board CD..
simple restart the PC it is required..
and for more queries post it on..
www.vk7.weebly.com
under the guest book..
i will sort it out as soon as possible..
Dec 04, 2007 | Manhattan 1100 Computer Speakers
No sound on my laptop
right click on the speaker icon and select properties and see if the sound is muted on the slider, if all is ok, click start>run then type 'dxdiag' and hit enter. look on the sound tab and it will tell you if there are any sound driver errors
Aug 02, 2007 | Emagic EMI 6|2m External Sound System
Microsoft Windows XP Professional Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
