Question about U-Line 75BWC
Stat thanks. I took the two screws out of the temp setting knob and pulled that out. There were two wires connected to it that had ends on them that slid onto the temp setting device. when I pulled one off and touched the end I got a little shock. Is that not the thermostat?
  • jdodaro Sep 08, 2008
    Maybe this is just beyond me but when I removed the housing where the temp knob was connected, it had two wires attached to it. Both had connectors on the end that slid onto the part. I pulled those two off. Are those the two wires that I should cross? Since they have the ends on them, I don't see how I can connect them together without having to cut the ends off and strip off some of the insulation.
Yes that is the 2 connectors to join together. if the connectors are not insulated, just tape them together or if an insulated type, use something like a paper clip pushed into each
Posted on Sep 09, 2008
    President:
  • 1,462 Answers
Always disconnect from mains when you do that sort of thing.
disconnect from mains, short the two wires together - just tape them together - and see if cooling starts
Posted on Sep 06, 2008
Why is my line voltage baseboard thermostat not shutting off at set temp?
I think you are right - it is the difference in wiring. On the ones that don't work, I suspect they are meant to run 2 baseboards each (hence the splices)
Run another black wire from the black splice and white wire from the white splice. Now treat these b & w wires as if they are from one baseboard unit and attach to the thermostat screws as the working ones are.
All this assumes that it won't exceed the capacity of the thermostat. If it does, you either need another thermostat for the second baseboard(s) or a relay that can handle higher current.
Be safe and good luck.
Please rate this 4 stars if it is helpful. Thanks.
Oct 24, 2017 | Heating & Cooling
Tip
Electric stove oven burning food?
if your oven is over cooking and or burning everything ,more than likely its your temp.thermostat it is not that hard to replace,before you do that go down to your nearest home depot or lowes or appliance store and get a portable thermostat they usually crome in color,take and set your oven to a temp like 350 for example put your new t.stat inside your oven and keep checkin to make sure it dont go above 350 if it does then you will need to replace the thermostat.to get to it first pull the t.stat knob off remember its the one you set the oven temp.with unplug range pull stove out away from wall so you can get behind it,you will have to take off all the screws that hold your cover panel on the screws are usually 5/16 nut driver.take the two screws off the front right behind where the temp knob is,mark the wires so that you do not forget where they go,, you dont want to hook them up wrong.it can cause alot more problems if they are put on wrong ok now,open oven door and you will see on the inside of the oven a copper wire that goes from the temp.control to inside your ovenall you have to do is take the wire and feed it through the back pull it out and take to your nearest appliance store make sure you write the model number and brand of the stove pick up the new one and put new one back on, put panel back on plug range in,and set temp back to 350 put the portable thermometer back inside oven should be good to start baking again
on Mar 09, 2010 | Kitchen Ranges
Top oven does not get up to the set temp.,as set on the control knob,could it be the stat or is it something else.Regards Graham Cooker is a Parkin Cowan Ovation 60GLXa
all ovens have 3 basic parts. metal cabinet. element and thermostat. if the element is heating, even if it is only slightly it will be the thermostat. if it doesn't heat at all it most likely will be the element but can also be burnt or bad wiring connections.
Mar 15, 2011 | Ovens
Oven is off 100 degrees. How to calibrate it?
To Adjust the Thermostat
Pull the OVEN TEMP knob off the shaft. look at the back of the knob and note the current setting before making any adjustment. The knob is factory set wit the knob directly under the pointer.
1. Pull of the OVEN TEMP knob
2. Loosen both screws on back of the knob
3. Adjust lower screw so it moves in the desired direction. You will hear and feel the notches as you turn the knob. Each notch changes the temperature about 10 degrees F.
4. Tighten the screws.
5. Return the OVEN TEMP knob to the oven.
Re-check oven performance and make the necessary adjustments accordingly.
Feb 12, 2011 | GE Spacemaker JMS08 Electric Kitchen Range
Wires got pulled out by mistake don't know what wire goes where the wire is old and discolored help!!!!
Is your wiring where it's hooked into the furnace still identifable as to color. If so one way to tell whats what is to remove wires from furnace one at a time and disconnect all wires from base of thermostat. Use a ohm meter and one very long test wire. Hook to known wire on one end and use test wire to check wires on t-stat end. When you read closed circuit reattach wire to furnace and lable t-stat end as to color. Connections on base of thermostat should be marked with R,W,G,and y. Check each wire one at a time and when you know what color each wire is hook t-stat base back up,put cover back on and check out. A much eaiser way if you can identify wire color and existing wire is accessible in basement or whever your furnace is . Discconect wires from furnace and see if you can pull wire back up to thermostat. If you're lucky they won't be stapeled inside wall. If you can move wire easily buy approximate length of new wire at hardware store. Most of them will sell wire by the foot. Strip about 3/4 inch of insulation from each wire and twist all wires from old to new and wrap all of it with electrical tape. Carefully pull new wire to t-stat and connect there and to furnace. Good luck. I hope this helps. Thanks
Nov 17, 2010 | Honeywell YCT87N1006 Heater
Kenmore Model # 110.26842691 my Heavy Duty Wash setting is not working.. is it a bad switch
The cycle switch is faulty or the Heavy Duty Wash terminal connection is loose. Check it first before ordering a replacement part.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The console is held to the cabinet by two screws hidden under the console end cap trims. Remove the end cap trims to access the screws by pulling or prying its top off the console.
Remove the screws at the front bottom corners of the console. Once the screws are removed, slightly pull the console to the front then flip it to the rear of the washer to access the switch.
Check the switch for any physical damage. Disconnect the wiring harness from the switch terminals and clean both the terminals and the connector. Reseat the connector several times to ensure good connections.
Replace the switch (part #3949181) when damage is found or when cleaning and reseating the connectors do not resolve the problem.
Pull the knob off the switch shaft and release the switch from the console. Install the new switch in place and insert the knob to the switch shaft.
Flip the console back to the top of the cabinet and align the tabs in the console end caps with the slots on the cabinet. Insert the tabs into the slots and secure the console to the cabinet with the two screws previously removed.
Mar 20, 2010 | Washing Machines
Temp does not follow what its set at
Pull the thermostat knob off. get a small flaslight and shine it into the stem for the knob. You will see a small screw down inside. turn the screw counterclockwise to adjust the temp to the dial. A little bit( 1/16th of a turn) at a time
Jul 22, 2009 | Imperial IFS40 Deep Fryer
Washing machine isn't moving beyond first setting
your machine is waiting at the thermostop position on the timer till its hot enough as per thermostat/timer temp setting,its probably faulty element or faulty stat ,id check the element first,it should have approx 20 to 35 ohms depending on wattage of machine,check element connections and heavy connection wires at timer for any burnt connections-hope this helps
May 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Temperature control knob turns but doesn't change temp.
the heater control valve is visible through the speaker cut-out; it's at the end of the plastic heater control rod, inside the car - not on the other side of the firewall! It's connected to the valve with a plastic "universal joint".
Check that the valve is actually being turned by the rod. The connection might not be good (pulled apart or broken), and or the valve might be stuck.
Saabreur
Mar 14, 2009 | 1991 Saab 900
Thermostat
stat is immediately behind the temp setting knob and inside a housing. prize off the knob and the housing is normally held by a couple of screws. take the housing off and stat will be in view
Sep 05, 2008 | U-Line 75BWC
Refrigerators Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
