Question about Fuji FinePix A310 Digital Camera
Can't use chargeable batteries
I bought 2100mAh Ni-MH battery charger. i don't understand why my Fuji A3100 digital camera can't use them. when i put the batteries in the camera, it simply doesn't work. what can i do?
    Novelist:
    Champion:
  • 277 Answers
If your camera doesn't work with NiMH, then it's most likely that you have either one or more bad atteries, or your camera is defective. p. 6 from the user guide: "..Ni-MH batteries left unused in storage for long periods can become ?deactivated?. Also,repeatedly charging Ni-MH batteries that are only partially discharged can cause them to suffer from the ?memory effect?. Ni-MH batteries that are ?deactivated? or affected by ?memory? suffer from the problem of only providing power for a short time after being charged. To prevent this problem, discharge and recharge them several times using the camera?s ?Discharging rechargeable batteries? function. By repeating this cycle several times, the temporary reduction in performance caused by ?memory? or ?deactivation? can be remedied and the batteries can be restored to their original performance levels. ..." Sorry i cant help you more..
Posted on Dec 26, 2005
SOURCE:
Can I use 4AA lithium Ion batteries in my Fuji SLR finepix s9600 .Thanks Les
It's better not to, Les.
Fuji suggest using AA Ni-MH batteries or simply alkaline. Others [e.g., Ni-CAD] can cause the camera to overheat and give real problems. Given the relatively low cost anyway, higher capacity Ni-MH batteries and a good charger unit seems the way to go - and will keep the camera healthy!
Aug 06, 2010 | Fuji Finepix S9600 Digital Camera
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
Battery level always shows as low, even when new, charged batteries are placed in the unit.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 20, 2009 | Fuji FinePix S2000hd Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
A850 fujifilm camer
Clicking noise it's because your batteries are not very powerfull!
Normal batteries it's not working for me!
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
Jun 28, 2009 | Fuji FinePix A850 Digital Camera
Ni-mh
yes ther is no problem using Ni-MH batteries, as they do not have a memory effect they will be better (subject to your charger), you can get the Fuji Finepix NH-20 batteries (wj=hich are NIMH) here - Fuji Finepix F420 battery
Dec 26, 2008 | Fuji FinePix F420 Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames) Recording Alkaline batteries : Approx. 80 frames Ni-MH batteries (2100mAh): Approx. 410 frames CR-V3 : Approx. 720 frames Playback Alkaline batteries : Approx. 275 min. Ni-MH batteries (2100mAh): Approx. 340 min. CR-V3 : Approx. 518 min.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
What is BP-400?
BP-400 is a exclusive external power battery pack for DiMAGE A1 and A2. It can be attached to the body and has portability and movability. It is very convenient for the customers who want to use AA size battery or take a long time picture. One or two exclusive lithium-ion battery NP-400 can be attached. 6 AA batteries; Ni-MH and Alkaline battery can be used. (Nickel dry battery and lithium battery cannot be used. Recording: Approx. 560 frames,continuous playback: Approx. 480 min.(2 pcs. NP-400 batteries) Recording: Approx. 290 frames,continuous playback: Approx. 270 min.(6pcs. 2100mAh Ni-MH batteries) Recording: Approx. 80 frames, continuous playback: Approx. 80 min. (6pcs. Alkaline-manganese batteries) Standard Accessory: Holding Strap HS-2 Optional Accessories: Dedicated lithium-ion battery (NP-400), battery charger (BC-400) INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V 700mA
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Fuji FinePix A310 Digital Camera Logo
94 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
