Question about Memorex MVD2042 DVD Player
MEMOREX DVD PLAYER
I AM GETTING SPLIT SCREEN AND A PSCAM WARNING IN THE MIDDLE OF MY PICTURE ON THE TV
  • Daniel Fernald Mar 18, 2012
    I know how I fixed the PS scan! and split screen problem on my Memorex DVD player. I looked at the back of the machine for a model number. I noticed a toggle switch in the back. I simply flicked the switch and the problem went away. This how I I fixed it anyways...
This was correct, I was ready to buy a new dvd player.Thanks
Posted on Oct 12, 2008
How to remove ps scan my dvd player is yto
Posted on Oct 09, 2008
There is a black button on the back of the dvd player..... switch it to off... it worked for me :)
Posted on Sep 08, 2008
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
I have a mvd 4544 dvd combo hooked it up to my new vizio tv and now i get a split screen with a yellow pscan box in the middle.
Do you have the dvd player set up as progressive scan? Most likely this is a settings issue. How are you connecting the dvd player to the tv as in what type of connection? Once I have more information I can assist you further.
Thank you,
Lee
Dec 11, 2009 | Memorex MVD2022 DVD Player
The dvd player displays a big yellow box in the middle of the screen with PSCAN with an exclamation point above it. Also the screen is showing the right side with a wide split between them. This is the...
I found the manual for this dvd player online. There is a switch on the back of the player. PSCAN is Progressive Scan. Some TV's are not compatible with this function so the switch must be turned off. This worked and I was watching a dvd last night!
Nov 03, 2009 | Memorex MVD2042 DVD Player
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
Can't get pscan split screen off dvd player, DSAY
I had the same problem... there is a switch in the back that got touched
Jan 24, 2009 | Memorex MVD2022 DVD Player
I work for Memorex technical support. Our customer service phone number is 1-800-919-3647.
On the back of your player you should see a switch that can slide back and forth that's marked PSCAN. Slide the switch into the opposite position from which it's in now. The should solve your problem.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 05, 2009 | Coby DVD-224 DVD Player
The screen is split ! PSCAN
Take a look at the back of the dvd player there should be a switch that says Progressive scan on/off. Switch it to off. Problem solved !!!
Nov 30, 2008 | Memorex MVD2042 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
May 16, 2008 | Memorex MVD2022 DVD Player
Split screen picture
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
May 14, 2008 | Disney D7500PDD Portable DVD Player
Memorex MVD2042 DVD Player Logo
141 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
