For this, Go to the Settings
Now you will be asked to enter the code. The code for all Nokia Phones is 12345. After entering the code the phone will restart and all the data in the phone memory will be erased.
Good luck and have a nice day..
If you want to reset or format your phone memory,be sure all important data is save or back up because it will erase eveything after the process and it will go back to its original setting as well.
On you home screen,just type *#7370# ,then it will ask for a lock code,enter your current code if changed it before,otherwise the default code is 12345. the phone restart and now your phone is in default settings.
If you forgot your lock code,it's better to bring the phone to any mobile service shop near you,they will just read the code using a gsmgadget,no data will be deleted as well.if the phone reads the code and it was already counter block,just ask for the code,don't let them format your phone,you can retrieve the given code by following this method.
* turn off the phone
* remove battery (for about 30 minutes or 1 hour)
* put the battery back and turn it on.
* enter the given code and this will open your phone.
Hope this solution helps....
