Question about Home
How do you install body jets for a shower
I have recieved 4 kyra body jets but no instructions, the jets have large nuts which I cant work out how to tighten up in the wall without putting a stud wall in. Any ideas?
    Novelist:
  • 171 Answers
Hi mickgosney
I'm Harvey the Master Plumber
Your question is how to tighten up in the wall without putting a stud wall in for kyra body jets.
Kyra sells about fifteen models and they are all designed to be installed in a wall of some type.
The wall lends some very nessessary support to the valve body so that the whole thing dosen't move when the handle is adjusted. Wood stud, metal stud and concrete are typical structures. If you are trying to install on a free standing shower I recomend at least some kind of creative frame to support the valve.
Feel free to contact me again.
Please give me a rating here at fixya.com before you sign off.
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
This shower has 3 body spray jets. The lower jet does not work. I need to remove the lower one to see if there is debris in the line, blocking it. It is a Kohler k 8002 cp body jet. How do I disassemble it...
There are some clips on the top of the spray head that fasten it into place. I found this pic that may help and your Kohler owner's manual should also have more info.
Mar 19, 2015 | Kohler Electrical Supplies
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
How to fit shower body jets
If you have good water pressure in your home and a tank water heater and not a tank-less, as long as all jets are space equally apart you should not have pressure issues. but running straight to a jet and splitting off from that point will cause a rapid loss in pressure to the other jets because the lack of resistance.
Fluid pressure is created by resistance to flow, not gpm (gallons per minute). If you flush a toilet and a faucet in another part of your home is reduced greatly you have a volume problem were the city water or well water is not supplying enough volume to your home and the multiple jets will not function correctly.
Tank-less water heaters have difficult times keeping up with the demand multiple faucets create.
Both problems have work arounds and fixes but it is best to get a certified plumper to install the components you would need
Jul 20, 2010 | Rohl Shower I00124 Ocean 4 Matching Twin...
How to install
Take a cloth or rag and a large pliers... place it around the nut of the old shower head and turn it to the left or counter clockwise as you are looking up at the shower head...
Then take the new shower head and spin it on there clockwise till it is snug...that's all there is too changing it...
heatman101
Apr 22, 2010 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Apr 06, 2010 | Danco Faucet Cartridge
Pressure to low
there might not be a large enough pipe suplieing the shower or bath room i would have 3/4 pipe at least to that bathroom. body sprays need alot of water
Oct 23, 2009 | American Standard R125 Pressure-Balance...
Shower body three way diverter problem, no water to one port
try taking the shower head off and see if there is something stuck in it. sometimes things will come through the water lines and lodge themselves in the valves as well. if the shower head isn't clogged try dismantling the valve that turns the shower head on and then turn the water on when its out and flush the port out.
Jun 11, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
One of Two bodyjets not working
there is a strainer in the valve body and the head if you remove head and look inside you should see strainer remove and clean. if it is in valve you made need plumber familiar with grohel
Feb 23, 2009 | Hansgrohe Shower 28466 Bodyvette Bodyspray
Source for installation insrtuctions
they normally come in the box but i beleive the valve body is marked. they are not on off valves they are a mixing valve make sure you have volume controls or they wont work in most cases
Feb 22, 2009 | Grohe Home
Home Logo
963 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
