Question about Panasonic PT-65WX51 65" Rear Projection Television
Big screen tv broken
My Panasonic PT-65WX51 TV turns on for 2 to 3 seconds and then goes off. What is causing it to "trip"?
    Novelist:
    Champion:
  • 277 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Dec 26, 2005
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Shuts off a few seconds after you turn it on
possible power transformer tv going into protection mode
Aug 25, 2009 | eVision EC720E 20 in. TV/VCR/DVD Combo
Tv has popped off after 2-3 seconds of turning on, now blurred im
well they may be shuting the set down convergence ic are 10 to 30 bucks a peice okay and if you dont really have a clue on how to replace i would say take to tv shop im not saying you can not do it yourself but you will need chem whic, pencil solder iron, heat sink and the right ecg replacement parts okay try it your self be careful try mcm electronics for parts if you lived in mid michigan i could help ya sorry good luck shad
May 05, 2009 | Panasonic PT-65WX51 65" Rear Projection...
Tv wont turn on
your power supply is bad and needs replaced
Oct 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
3D images
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Can't get full screen
What does "8 inches on each dark" mean? you can try the format button on the remote and see of this will fix it.
Mar 15, 2008 | Panasonic PT-65WX51 65" Rear Projection...
TV will not power on. Slight electrical smell
Find out what is burning and replace it. Or call for service if that is beyond your ability.
Jan 13, 2008 | Panasonic PT-65WX51 65" Rear Projection...
PT-65wx51e 65in
suddenly breaks pink & green colors in bottom left & top right corners with distortion in picture
Dec 09, 2007 | Panasonic PT-65WX51 65" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
