Question about Nintendo DS Lite Console
Nintedo ds lite
My sons nintendo ds lite, he as some how damaged the pins in side the ds lite were the ds cartridge slots in so now when he puts a ds game in it does not connect properly hence cant play game due to bent pins in ds lite CAN THESE BE FIXED ?
  • 1 more comment
  • nbennett13 Sep 06, 2008
    When I put a ds game in it won't come on to the screen. I have tried nothing yet.
  • contjes Oct 02, 2008
    ds games not working
  • AlwaysChaos Mar 03, 2009
    My son stuck his stylus into slot 1 and bent the gold prongs. now his games wont fit in properly
    Master:
  • 505 Answers
Yes it can can cost anywhere from $20 up
from any Repair shop
Posted on Sep 06, 2008
  • Do Not put the game in could damage more pins wait till its fix mate thanks viper
DS Lite Console: my nintendo ds lite won't read game cards...
try compressed air.
more then likely its a hardware issue. try getting an R4DS card and download games from www.filestube.com if you dont want to repair it.
you can have 50+ games on an sd card and not have to lug around all those games anymore
May 06, 2010 | Nintendo DS Lite Console
Nintendo DS Lite not reading game when you put it in. Will say no cartridge??
This is a very common problem and is usually due to either dirty orcorroded pins in the game slot or a bent pin. Sometimes it can be the game contacts are a bit dirty but if its the same with all games then its the slot pins.
It is sometimes possible to clean the pins in the slot with some fine abrasive paper rubing the pins in an in and out motion, not side to side. The pins are extremly delicate so you may end up bending a pin which basicly leaves you with a slot change.
It an easy job with the right tools and a bit of skill using a soldering iron.
Jun 03, 2009 | Nintendo DS Console
Game slot has been damaged on nintendo ds
I can give you some answers but might not work. See if the slot where the Ds game suppose to go needs to be cleaned.Take a pice of cotton from the cutip and put it on your stlyer(DS stick).Clean inside of it.Stiil dose not work and have a warranty go get the ds repaired.DO NOT PUT LIQUID IN THE DS SLOT(WILL NEVER WORK AGAIN TILL REPAIRED).
Dec 30, 2008 | Nintendo DS Lite Console
Nintendo ds bent pins
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but this part is too impractical for most people to attempt a repair.
However, if you are savvy enough to attempt the repair of the damaged pins on your DS Lite, here are my recommendations:
1) Cut a flap in the slot-1 port cover and straighten pins.
2) Replace the main board.
3) Remove the slot-1 port cover and straighten pins.
4) Remove the damaged pins from the slot-1 port and straighten.
5) Replace the slot-1 port.
All of these recommendations require disassembling the DS Lite using a specialized triwing (or Y) screwdriver and a lot of patience. The following video will help in disassembly: http://www.youtube.com/watch?v=HQlTpTLUyFQ.
Recommendations 3 to 5 all require solder work. Recommendation 3 requires solder work for 4 solder joints, 1 at each corner. Recommendation 4 requires solder work for up to 17 solder joints, one for each damaged pin. Recommendation 5 requires solder work for all 21 solder joints.
Dec 10, 2008 | Nintendo DS Lite
Ds lite pins
From outside is pretty difficult to straight the slot 1 pins as it is small and you need very thin pliers and light source plus lots of patience.
With a plier you can straight the bent pins to its right position, but make sure the pin is not out of its place as all the pins are V wedge shaped and the pin comes from the slot bottom, the edge fits in a small hole then goes up to make contact with the game cartridge contacts. No one stay out when inserting a cartridge or you'll have a bigger problem.
If there are many bent pins I find more easy to open the DS, desolder the damaged pins and pull em out of the plastic enclosure to repair it, put it in again and re solder. No one option is easy... Sorry...
Nov 16, 2008 | Nintendo DS Lite Console
Nintendo doesnt work
I know how to fix that all you do is blow in the ds game slot to make sure it is clean then after that make sure the ds game is inserted propply
Abz
Sep 03, 2008 | Nintendo DS Lite Console
Nintendo ds lite - son putgame cartridge in wrong way and has bent a pin on the console - fixable or not?
The part with the damaged pins is the slot-1 port. I know it seems rediculous, but it is too impractical for most people to attempt a repair to this part.
Aug 27, 2008 | Nintendo DS Lite
Nintendo DS Lite - Problem w/ Console not Recognizing Game Cartridge
The problem is that over time the console pins that contact the game catridge gold contacts bend and no longer contact the catridge. DSi has solved this problem by adding a spring that will push the catridge firmly against the pins. So Nintendo must have recognized the problem (a serious design flaw worthy of a class law suit since 4 DS lite at home had a similar problem. I fix the problem in one of the old "broken" consoles by adding a "bumper" made of folded paper on the catridge, opposite to the contacts. This rudimentary added pressure on the pins fixes the game freezing and all the games work now. I feel chated by Nintendo after spending over $600 to replace broken consoles. They usually break after about a year.
Jul 16, 2008 | Nintendo DS Lite Console
My ds lite will not read any games
You may have a bent pin on the game slot. Try inserting a game several times rapidly in and out. Look at your game cartridges and see if one of the contacts is damaged in the same place on all of the cartridges.
If this does not solve the issue, you will need to get your console repaired. Either the repair shop will replace all of the electronics or resolder a new game slot on your existing board.
May 25, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
668 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
