Question about Dualit Vario Combi 2x2 65-Slice Toaster
Dualit toaster 3 slot- how do you replac the element
  • 1,711 Answers
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Posted on Aug 20, 2010
Dualit ,model 3 combi doesn't work. The signal light doesn"t goes on either. As far as I can measure the timer works, what can this be?
Posted on Sep 18, 2011
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 37 Answers
SOURCE: Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Posted on Nov 20, 2008
juliant61
SOURCE: Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Posted on Nov 30, 2008
cactus bob
  • 267 Answers
SOURCE: Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
espressonist
  • 1711 Answers
SOURCE: How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
Good luck
Dualit toaster repair manual
if its a bullet thermal fuse you can buy these on ebay for nutin.
if you want u can put in a programmable thermal control or just a resettable button fuse it resets its self when it cools . (looks like a button )
Aug 17, 2014 | Dualit 6 Bun Slot Toaster Heating Elements...
Can you supply an end element for a Dualit 4 Slot Toaster Serial Number 01/96 Code13. Thank You john Lynch
Hi John,
FixYa doesn't suplly any products or parts. This is an online community of experts who help users fix their product related problems.
For your Dualit toaster, you might want to check the Dualit website:
http://www.dualit.com/support
Hope that helps
Jun 21, 2010 | Microwave Ovens
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit Combi model (made in UK)
service center in US:
Electra-Craft
41 Woodbine St
phone 201-439-1700 ask for Steve Karow
fax 201-439-1701
Oct 28, 2008 | Dualit Vario 3 Slices Toaster
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Dualit Vario Combi 2x2 65-Slice Toaster Logo
247 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Angel Joseph Jr.
Angel Joseph Jr.
Rabbit Brains
Rabbit Brains
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
