Back to:
Tags:
Brother LS-2125 Mechanical Sewing Machine
Tension (by 3 users)
posted by sbogener328 on Sep 06, 2008
sewing on cotton pants, the thread tension on top is fine but the underside has loops. where should the dial button on the front of the machine be set.
I have not adjusted anything else. it is now on 0 what number should it be on?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Nov 13, 2008
I have the same problem, top thread tension is fine, but the underside has loops. I've played with the top tension and the bottom tension, nothing has worked. At this point I fear I'm going to need a new machine.
Comment by rbnelson03, posted on Nov 11, 2008
I took my machine in for repair and was told that this machine isn't worth the money to have it corrected. HELP! there isn't anything else wrong except the lower stitch has loops sometime. how do I get the bobbin tension right?
Solution #1
posted on Sep 13, 2008
Not Rated (0)
5hadow
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
5 is the default tension.. if you are not satisfied with it try to adjust a little.it a try and error
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tension:
I don't want to Accept this solution
Solution #2
posted on Sep 06, 2008
Not Rated (0)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1421 votes
Top tension between 4 and 6.
Thank You!
Can you Help with these Sewing Machines problems?
My Brother SP53 mechanical Sewing Machine is sewing...
My husband bought this sewing machine, brother LS-2125,...
I have an industrial brother sewing machine (model...
my Sewing machine is not making stitches
Just the simple way to thread the 3 cottons, with settings...
Loading problems.
Repair Service
Find Sewing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
